Question about Kenmore 600 6965 Electric Dryer
I have a kenmore 600 dryer model #110.69622800 it won't start ,glow plug lights up , door switch goes on and off
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
gamefixer
  • 6 Answers
SOURCE: Kenmore 80 series electric dryer will not start even though the door switch switch appears functional and power is getting to the timer.
Easy fix. I had the same problem on mine. You need access to the back. Remove back cover. Look at bottom left, you will see two blue wires going to a white plastic item next to one of the thermal sensors. This white plastic piece is a fuse, or fusible link if you like. I'm not sure what the rating is, but you can take the old one to a parts store. They can match it. Now, why did it blow? Well, if the dryer is old, it could be just worn out. But more than likely, one of your 230 volt lines has degraded due to a bad connection, thus drawing more amps, thus blowing the fuse. Look at where the power cord comes in at. Is there any discoloration or oxidation at the terminals? If so, replace the power cord at this time, and try to clean up the terminals as best you can. Also, at this time, you probably better take a look at the lint collector duct running along the left side down the back. It's probably so clogged with lint that your dryer does't dry as fast anymore, and air flow from the exhaust is restricted. Take the duct off and clean it out, or blow it out with compressed air. You should be up and running now. Have fun...
Posted on Jun 16, 2009
SOURCE: Kenmore Model 96573220 won't stop at end of cycle.
I figured out it was the start switch and took the switch apart and repaired the welded together contacts. Took only a few minutes.
Posted on Dec 28, 2009
SOURCE: kenmore 600 series gas dryer not warm
My Kenmore 600 gas dryer is running but it does not heat, so I'm not able to dry my cloths.
Posted on Sep 12, 2010
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
Why does the inside light stay on and the Kenmore dryer won't start when the door is closed?
There is a switch in the door jamb that turns on the light and also allows the dryer to start. If you close the door and the light does not go off like it did before, then that switch is probably bad.
Aug 29, 2011 | Kenmore Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
Kenmore 600 6965 Electric Dryer Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
