Question about HP Deskjet 2512 All-in-One Printer
My printer has an orange exclamation point blinking
I tried to print a picture but the printer has an orange exclamation point that's blinking.
  • 58 Answers
SOURCE: error light
it detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
Posted on Dec 06, 2007
SOURCE: I have a HP LaserJet 1320n printer and it will not
Possible Solution to your issue!
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
Posted on Feb 23, 2009
SOURCE: The orange light on my printer is flashing next to
It is out of paper.
Posted on Sep 11, 2009
ur fortune
  • 85 Answers
SOURCE: Won't print. The triangle with the exclamation
may be the drivers of printer are not installed properly or ink might not be there or the ink has been dried.............kindly check for possibilities,,,,,,,,,,,,,,even check for proper connections
Posted on Oct 15, 2009
  • 232 Answers
SOURCE: exclamation point blinking and will not print.
Try turning your printer off, wait for 10 seconds, then turn it on again. If nothing changes, I think you should check your cartridges. Remove them from your printer and gently wipe the contacts with a dry cloth, then put them back in. If that doesn't help either, one of the cartridges might be dead. The symptoms you described point pretty much to that conclusion. Try taking out one of the cartridges and see if the paper sign is still blinking. Do the same with the other cartridge. The one that prints is fine, the other one should be replaced and that should fix your problem.
I hope my comment was useful!
Posted on Apr 01, 2010
Testimonial: "The suggestion worked and our printer was fixed. Thanks!"
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
Oct 14, 2011 | Dell 1710 Laser Printer
The printer cant print it keeps showing "!" or
The blinking exclamation point means that the cover to the printer is not closed all the way. Try opening and closing the cover to get rid of this error. If there is another picture like an ink drop or a sun that is also blinking at the same time then the error can mean something different.
Here is a link to your manual for your printer that includes troubleshooting erorr codes:
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Oct 14, 2011 | Dell 1710n Laser Printer
Won't print, orange triangle with exclamation point
This triangle light blinking indicates that a door is open. Open the front access door completely. Close the front access door completely. Open the rear door and close it.
If this didn't fix it refer to this guide for all errors you get with this printer from HP website.
Dec 16, 2010 | HP LaserJet CP1215 Color Printer
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
Orange exclamation point is blinking, screen says "replace supplies", but it says that all the time. Nothing will print or copy. It will scan the document like it's going to copy, but then just stops....
I'm a tech on that printer. That's a generic message if one cartridge is at 0%. When one toner or drum reach 0 it wont print even though you don't use that supply. The unit should show the level on the screen, if one is empty replace it.
Aug 04, 2010 | HP LaserJet 2840 Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
HP Deskjet 2512 All-in-One Printer Logo
222 people viewed this question
Seeker5211
Seeker5211
