Question about Kenmore 22422 Top Load Washer
Kenmore 70 series Washer will not drain or go into the spin cycl
When the wash cycle stops the water does not drain nor will the spin cycle start.
    President:
  • 1,185 Answers
There is a pressure switch that inhibits the machine from doing something stupid like spinning with a load of water in it.
Quick test is to blow hard down the outlet pipe, put a tissue around it to protect you mouth
If you hear air bubbles inside that machine it meand there is not a major blockage.
If there is a blockage such as a sock or underwear then the hoses need to come off to clear it
Take out the filter and see if there is a coin or a hairpin or similar holding back the impeller of the pump.
If you can reach the impeller with your finger see if you can turn it (Or use a skewer)
If air goes through and the impeller turns then it is either the programmer or the pump coil.
To fix that you need a test meter and some knowledge
Posted on May 21, 2009
hotuna
  • 288 Answers
SOURCE: Kenmore series 70 washer
On kenmore, which is made by whirlpool, there is a couple of coils attached to a bracket this is called a wig-wag.
they are located underneath the tub. when these coils engage they move a couple of bars, thus selecting agitate, spin, ect. It sounds like one of the coils is not working. Check them for power and continuity, and then go from there.
Posted on Nov 05, 2007
  • 112 Answers
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
If the unit is still agitating as it is supposed to, this is usually due to a faulty lid switch.
Posted on Oct 25, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer won't drain
The symptoms you describe are typical of a lid switch failure. When a lid switch fails, the washer will fill, but stop at the spin cycle and will not drain. Sometimes it will fill, then stop. The switch is located under the washer top cabinet on the right hand side and is activated by a small plastic piece on the lid (called a "lid strike") through an opening along the right hand side of the casing next to the wash tub opening. First, make sure the lid strike is still intact on the lid. Next, open and close the lid and listen for a "clicking" sound. This is an indication that the lid strike is at least making contact with the switch. Then, check the two screws along the right side of the wash tub opening that hold the lid switch in place. Sometimes the screws come loose or fall out causing the switch to fail to contact the lid strike. In many cases, all that is required is to tighten these screws to realign the switch with the lid strike. If all these preliminary checks fail, the lid switch should eb replaced. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require parts, go to searspartsdirect.com and type in the model number you provided. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike is listed as item number 20.
Some other sites to view are repairclinic.com and appliancepartspros.com. Sometimes these sites offer better pricing on parts.
If you have questions, or if the diagnosis is incorrect, please post back and let me know. I hope this helps you.
NOTE: If the wash tub is full, you DO NOT have to empty to complete this repair. Once a defective switch is replaced, the washer will spin out and drain on its own.
Posted on Jan 23, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore 70 Series Washer
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Posted on Aug 20, 2009
SOURCE: Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Posted on Dec 01, 2009
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Water won't drain
This is usually caused by the lid safety switch. When the switch malfunctions, The washer believes the lid is open and the washer will not spin or empty. The switch is intended to prevent injury during the spin cycle. The timer could be bad but it is usually the switch..
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
210 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
