Question about Netflix
(Error code: ssl_error_rx_record_too_long)
I am trying to sign in to Netflix but I keep getting the above error message.
    Top Expert:
  • Netflix Master
  • 14,161 Answers
Posted on Mar 15, 2016
4 Suggested Answers
ssheol
SOURCE: netflix Player Error 1001
I tried everything to fix the 1001 error, and finally fixed it by simply uninstalling silverlight, then RUNNING THE INSTALLER AS ADMINISTRATOR. Boom.
Posted on May 08, 2012
  • 84 Answers
SOURCE: Can't get Netflix. Getting error code 51330
This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
Posted on Jun 29, 2014
ElDopa
  • 295 Answers
SOURCE: I can't get connected to Netflix. I keep getting
That sounds like a Nitendo Wii errorcode; assuming your using that to watch Netflix:
From the tech support website: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Error Code: 51030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Click here for info on setting up your Wii: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
In other words; you Wii doesn't seem to be connected to your WiFi network anymore ...
I can't get connected to Netflix.All that pops up is error code 209826
1 (866) 579-7172
this is Netflix customer support phone number. Basically their are at least 9 way to contact them the link is below. Good luck.
https://gethuman.com/contact/Netflix/more
Dec 30, 2014 | Netflix
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
16003 error code on my phone for netflix
Sign out of your account, then delete netflix then get it back. BAM! your done and working again.
Dec 13, 2013 | Netflix
Trying to access netflix, ssl error keeps coming up and cant open also doesnt get my email, not in data base, why.
Be sure to mail or password
Or it may have been the expiration of the subscription in the company can check back through the following link:
https://contactus.netflix.com/contactus?locale=en-PS
Oct 19, 2013 | Netflix
How to fix Error 80070002 "Service is temporarily unavailable"? Trying to sign into Windows Live Messenger and I keep getting error number 80070002, what should I do?
Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
d. REGSVR32 Rsaenh.dll
e. REGSVR32 Mssip32.dll use reginout cleaner to fix it easily
Oct 08, 2010 | Microsoft Windows Live Messanger
While accessing mail i am getting message (error code:ssl_error_rx_record_too_long_
Error code: ssl_error_rx_record_too_long Your SSL website may fail to load and display the error
This usually means the implementation of SSL on your server is not correct. The error is usually caused by a server side problem which the server administrator will need to investigate.
Below are some things we recommend trying.
- Ensure that port 443 is open and enabled on your server. This is the standard port for https communications.
- If SSL is using a non-standard port then FireFox 3 can sometimes give this error. Ensure SSL is running on port 443.
- If using Apache2 check that you are using port 443 for SSL. This can be done by setting the ports.conf file as follows
— clip —
Listen 80
Listen 443 https
— clip —
- Make sure you do not have more than one SSL certificate sharing the same IP. Please ensure that all SSL certificates utilise their own dedicated IP.
- If using Apache2 check your vhost config. Some users have reported changing <VirtualHost> to _default_ resolved the error.
Mar 18, 2010 | MPC Computers ClientPro 125D PC Desktop
Error code 80072745
http://www.tweston.co.uk/2008/07/26/windows-live-messenger-problems-80072745-solved/
This error is fixed by the solution here.
Nov 05, 2008 | Microsoft Windows Live Messanger
Netflix Logo
78 people viewed this question
Top Netflix Computers & Internet Experts
David Payne
David Payne
arcada
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
