Question about Delta Enterprise 50-870 Air Purifier
DELTA 50-870 DUST COLLECTOR WON'T START
I BOUGHT A USED DUST COLLECTOR, WITHOUT TRYING IT FIRST,I PLUGGED IT IN AND THE GREEN LIGHT COMES ON BUT NOTHING ELSE WILL WORK THE FAN DOES NOT START
How do i stop the red lite for the collector cell to stop blinking ?
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
Mar 21, 2011 | Oreck XL Professional Air Purifier
I have bought Ionic Pro Turbo Air Purifier recently in USA and moved out of the country after the purchase. When I plugged in with right electricity voltage & watts, my purifier starts with green light...
Hi Sathish, I work for the Ionic Pro company. What country are you trying to use the unit in? This will help me determine how to assist you. Thank you, Mary
Feb 15, 2011 | Ionic Pro TURBO Air Purifier
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Check collector cell
sounds like you need to clean the cell
Jul 26, 2009 | Oreck Professional Air Purifier Air...
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
Collector cell light always comes on
We purchased one of these in April 2009. Same issue appeared with us. Cleaned the cell and the "clean collector cell" still stayed illuminated. Checked the manual and the trouble shooting section stated to hold down the "air revitalizer button" till the "clean collector cell" light blinks three times. After this operation the light went out and all was fine!!!! Hopes this clears your issue!
Feb 02, 2008 | Oreck XL® Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
User Manual
The only cartridge is the included 'stainless steel collector grid' (removable for cleaning with cloth, don't use vinegar), there's no air filters that need replacing.
According to the manual:
SIR setting (Super Ionic release) creates lots of negative ions which not only gives a prior-to-rainy-day fresh energetic atmosphere that relieves headaches, but also if comes into contact with dust, will attach to the dust and make them heavier to drop them out of the air.
SOS setting (Super Oxidating Sanitizer) turns oxygen O2 molecules to O3 molecules, which if comes into contact with odor or dust will discharge 1 O atom into the pollutant to neutralize it. Also, like SIR, it introduces negative ions that attach to dust and makes them fall to ground, but not as much,
Both settings tackle dust/pollen/smoke with SIR doing it faster. Only SOS can neutralize organic odors. I recommend SOS because if you leave it on long enough it can do the same job as SIR, as well as make the room smell fresh.
Oct 04, 2007 | Lentek IO10G Air Purifier
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but  the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
Sep 06, 2007 | Filter Queen Defender Air Purifier
Delta Enterprise 50-870 Air Purifier Logo
Top Delta Enterprise Air Purifiers Experts
Are you a Delta Enterprise Air Purifier Expert? Answer questions, earn points and help others
