Question about Home
Moen troubleshooting cold water dosent come out strong just trickels
4 Suggested Answers
  • 22 Answers
SOURCE: cold water rinse just trickles on my whirlpool heavy duty top loader
There is a screen inside the inlet valve that is most likely plugged. Turn off the water and remove the cold hose from the washer inlet valve. You can see the screen just inside the valve. If the particles are a light brown color, it may be water softener resin, requiring a softener repair. Foreign matter can also include sand or other particulates in the water supply.
Posted on Apr 25, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 342 Answers
SOURCE: Washer is filling very slow.
turn off the water supply unscrew the filling pipes and look in the end they usually have a wire gauze filter check for blockages ie limescale
Posted on May 30, 2011
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I want to install Moen Caldwell faucet CA84440. Please tell me how I can connect cold water pipe to the pipe below the knob handle? No instructions regarding this are included in the box.
part K ( a three way hose it looks like) hooks up the cold and hot water to the water spout. heres a link to look at! copy and paste in your browser window.. hope this helps ! craig
http://www.moen.com/shared/pdf/instruction_sheets/INS1970.pdf#xml=http://search.moen.com/cgi-bin/texis.exe/webinator/moensearch/xml.txt?query=CA84440&pr=WMC_Other&hpp=10&order=r&cq=&id=4a89f5ab7
Aug 27, 2009 | Moen Plumbing
Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Aug 17, 2009 | Plumbing
Water barely trickels in
Could be low water pressure, test by opening the cold tap/faucet on the nearest sink.
Hoses could be kinked, or taps not open or clogged with grime, also there may be filters washers fitted to the hoses, on either end.
Or the valves in the machine could be faulty.
Jul 04, 2009 | Washing Machines
Cold water rinse just trickles on my whirlpool heavy duty top loader
Apr 25, 2009 | Washing Machines
Hot water faucet turns wrong direction
You have a cold side valve part assembly in a hot side. Order for free@
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 03, 2009 | Moen Plumbing
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
188 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
