Question about Canon Office Equipment & Supplies
Copies not dark enough - Canon Office Equipment & Supplies
How to dark Copy for Ricoh mp 2500 photo copier
Hi
first clean up optic section under expousured class. If the printed sheet is OK, but the copied one is not dark enough, then probably you OPC(drum only) is not well charged. In this case you will have to replace it. In our country it cost about 20 Euro.
Good luck
Pifonski
Nov 27, 2015 | Ricoh Office Equipment & Supplies
Tip
Troubleshooting MINOLTA DI 1611, DI 2011
The copy is too light. The copy density is set too
light.
Use the Auto/Photo
key to select a darker
copy density .
The copy paper is damp. Replace the paper.
The copy is too dark. The copy density is set too
dark.
Use the Auto/Photo
key to select a lighter
copy density .
The document was not
pressed close enough
against the Original Glass.
Position the document so
that it is pressed closely
The copy is blurry. The copy paper is damp. Replace the paper.
There are streaks through the
copy.
There are specks throughout
the entire copy.
The Original Glass is dirty. Wipe the glass with a soft
dry cloth.
The document pad is dirty. Clean the document pad
with a soft cloth dampened
with a mild detergent.
The original is highly
translucent, such as diazo
photosensitive paper or
OHP transparencies.
Place a blank sheet of
paper over the document.
A double-sided document is
being copied.
If a thin double-sided
document is being copied,
the information on the back
side may be reproduced in
the copy. Use the Auto/
Photo key to select a
lighter density for the
background.
The Imaging Unit has
reached the end of its
service life.
Contact your service
representative.
on Dec 18, 2009 | Office Equipment & Supplies
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Error 9.334
That machine is not detecting a dark enough copy. It creates a patch on the belt and measures the darkness.
The most likely problem is a bad donor roll in the developer housing. That is the most common cause of that code.
It is possible that one of the gears on the toner dispenser have broken , I would not rule that out either.
Feb 15, 2010 | Xerox Document Centre 490ST Laser Printer
When i take copy from ricoh 2015 the copier result is very low
You mean it is not dark enough?
It is either dirty optics, or worn out developer, or both
Dec 29, 2009 | Ricoh Aficio 2015 Copier
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
Contrast of copy
Your ink is no more ink inside.
Jun 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Copies are not dark enough
No. This really needs to be done by a tech, it is quite complex, and the optics also should be thoroughly cleaned beforehand as well, in order for it to calibrate properly.
Please rate me :)
Mar 25, 2009 | Canon NP 6035 Copier
Dark line when trying to make original copies.
The type of printer you have reads the image you want to copy by passing the paper in front of a image reader (it is like a wand with a light-slit on a side).
If someone passed in front of this reader a paper with something like dirt on it (or typing corrector not dry enough) some of that could stick ON the light-slit, so that the section covered with it cannot read any more the image you want to copy at that point!
Try to make a copy and look from above or aside where that light-wand is located, then try to clean it with a clean hanky. It could involve some technikal skills, maybe you have to loose some screws to get to it.
If dirt stick on it after this, try with some alcohol (no solvent please!). After cleaning the reader, copies should come out ok, please let me know.
Rate the solution please! Thx
Jan 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
16 people viewed this question
old marine
old marine
