Question about Refrigerators
Ice maker is afflicted
Unfortunately i don't know anything about this side by side. i do know that the ice maker is making "incomplete" cubes. I know that isn't very clear. Perhaps saying the cubes are hollow will help. they seem to stick then to the "teeth" at the top of the maker. i understand if this is way too confusing:)
  • mom21sweetie May 23, 2009
    i did one thing...i turned the control that makes more of the cold air direct to the freezer. i didn't set it colder or anything. just that. it was the cure. right on. we got this fridge free so it's so nice to have everything work. thanks again for all of your help. this site rox!
  • 10,865 Answers
Hello there. Sorry for your trouble. Your problem is common. I will try to help u. here is some information to get you started:
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Get back and let me know if this helped and what is still a problem.
Posted on May 21, 2009
  • Joe Hogan May 23, 2009
    excellent! Thanks for getting back.
Ice maker make ice but not come out
Hi there! If the ice maker is making ice properly but is not pushing it through tot he bucket or to the door dispenser, it is clogged somewhere. This could be from melted ice cubes blocking the pathway or even a faulty switch arm (or auger) that pushes the ice cubes forward. Check those areas and let me know if you find anything additional or out of place. Also check for any cracks in the ice maker housing.
Mar 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
The automatic ice cube maker continues to make ice cubes when the tray is full. It also dispenses crushed ice when the Cube option is selected.
You have a frozen selnoid that opens a door to let ice to pass crusher. And also the ice maker needs a different arm so not to make too much ice. You will have to call a tech to do the job. But now you know what is wrong. I hope this helps.
Aug 23, 2011 | GE GSH22JFT Side by Side Refrigerator
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Cubed versus Crushed Ice Cubes
I have the exact same problem with my LG SXS refrigerator.
Jul 24, 2008 | LG LRSC26920TT Side by Side Refrigerator
GE Side by Side: Ice Maker Issue
Is the freezer working at the correct temp ?? Is the ice maker feed pipe blocked ??
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
