Question about Canon USA Faxphone L100
Prepare toner cartridge warning message
What does this message mean?
5 Suggested Answers
spinal
  • 287 Answers
SOURCE: Clear Error Message
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
Posted on Jul 19, 2008
  • 5 Answers
SOURCE: Hello I have a canon lbp2900
Just open the door and pull it out the toner cartridge, inside the printer in left hand side u will find a sensor in grey or while colour , from ur finger just check its functioning (up and down function) if it fails then open the back side cover there u will find one metal plate in silver colour open it and in right hand side there are sensors the cartridge sensor is also there only in right hand side refitted it and ur problem get resolved
bye
wasim
Posted on Jul 30, 2009
SOURCE: Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Posted on Apr 26, 2011
  • 49 Answers
SOURCE: Canon MF6590 will not print fax pages if it thinks
this is let you check if your toner really is out:
http://www.quikshiptoner.com/catalog/canon-mf6590-toner.html#When_to_Replace_the_Toner_Cartridge_in_a_Canon_imageCLASS_MF6590_Printer
Posted on May 26, 2012
Replaced black toner cartridge (Genuine) Now getting message: Prepare Toner, red flashing light.
Did you pull the tab that pulls the cellophane strip out of the toner cartridge?
Jul 10, 2017 | Black Office Equipment & Supplies
What does prepare toner mean
If the printer is a Samsung, then it means the toner cartridge is reaching its end of life, you need to have a new toner cartridge ready to replace the empty cartridge.
Featured products
Sep 30, 2014 | Office Equipment & Supplies
Prepare toner cartridge message
I believe it's a counting sensor ( or something like that) look up your model on google, and 'reset counter', should have instructions might be as simple as taping over a lever inside printer
Oct 31, 2013 | Canon Laser imageCLASS MF4880dw Wireless...
Black cartridge error
First, check to see that a toner cartridge is in fact installed.
Open the toner access panel and remove the cartridge.
Check to see if it is indicating that it is empty. If so, replace the toner cartridge and wait for the error message to clear as the machine prepares the new cartridge for printing.
Dec 20, 2012 | Lexmark X4650 InkJet Printer
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
Samsung 4623FN when i refill the catrdige second time it shows me as. End of Life replace with new catridge..
  1. Prepare a new cartridge of the color (K, C, M or Y) you wish to replace.
  2. Ensure that the printer is on with all covers closed, and that the Toner Low warning, Sleep, or Ready status is displayed.
  3. Press the right%20arrow%20black.jpg Right arrow button to display the menu.
  4. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Reset Menu is highlighted:
  5. Press the right%20arrow%20black.jpg Right arrow button once, this will enter the reset menu as shown below:
  6. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Change Toner X (where X is K, C, M or Y) is highlighted for the toner you wish to change:
  7. Press the Right arrow button to start the removal procedure. The printers panel will read Please wait, then after a short delay the printer should display a red error light and the message Replace Toner X, where X is the relevant toner cartridge:
  8. Open cover D.
  9. Hold the toner cartridge knob and tilt it toward you.
  10. Remove the empty toner cartridge from the printer.
  11. Take the protective materials off of the new cartridge, and gently shake the new toner cartridge a few times.
  12. Take the new toner cartridge out of its package, and remove the plastic protective cover from the toner cartridge.
  13. Insert the new cartridge into the printer.
  14. Close the toner cartridge cover.
  15. Close cover D.
  16. If you need to change another toner cartridge, repeat the above procedure from Step 1.
TO view pics of the steps click here
Apr 19, 2011 | Samsung SCX4623F Laser All-in-One Printer
System keeps initializing, will not allow you to copy or print. the message also states toner low prepare new one. we have inserted a new cartridge. i've turned have unplugged and turned it, waited 5...
Are the machine making noise that sounds like something is turning? If yes, that means that the machine replenishes the toner. Give her a little more offs and ons.
If does not help call service.
Jun 15, 2010 | Canon imageCLASS MF6590 Copier
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
Canon USA Faxphone L100 Logo
old marine
old marine
