Question about Whirlpool GHW9400 Duet Washer
Grey front seal holding water
Whirlpool Duet washer front gray seal has a puddle of water after every load. Lowe's tells me that is should have dropletts of water on it anyway and to just leave the door open???
  • amdmorte May 21, 2009
    I spoke to customer service @ Whirlpool and they told me that it shouldn't hold water. Lowe's is bringing me a new machine tomorrow I guess we will see if this one holds the water also.
    Machine is 1 month old.
    Thank you for your help
    President:
  • 1,185 Answers
Old machines used to have a drain hose in the bottom to take that water away however they tended to snap off and allow water to leak on the floor .
On new ones they accept that water will lay in the gasket.
If it bothers you try putting a strip of Vileda cloth into the gasket at the end of the wash to soak it up .
It is bright enough to see and to remind you to remove and dry it.
Add a little Soda Crystal to the soap drawer , thsi softens the water and stops smells
Posted on May 21, 2009
  • Tom
    Tom May 21, 2009
    Its all down to the wrinkles
    Thats why old people do not like going out in the rain
Broken ceil on whirlpool duet front load leaks water from rubber part
You need to get a new seal. You can probably change this yourself. There is a wire clamp holding it in place that you will have to remove before getting the old seal off and installing the new seal. Finally, you will have to replace the clamp.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Always have left the door open and faithfully have followed monthly cleaning cycles. I still have a musty odor and the gray seal looks disgusting. I wipe the washer and seal and inner seal drum all the...
have you been using the affrresh cleaning tablets and emptying the filter sump after you run a clean cycle ... if the washer seal thats suppose to be grey is black you can attempt os scrub it with vinegar and scouring pad but most of my coustomers end up replacing it when it get that far along ....
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from whirlpool front loading washer when washing heavier loads
Check your rubber seal in the washer by the door and make sure your getting a good seal. Part of the seal has probably pulled loose.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW@ whirlpool Duet grey seal leaks
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
374 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
