Question about Dryers
I have a zanussi zdc47209w and it is no longer drying my clothes ???????
SOURCE: Clothes not drying...
need a new thermostat
Posted on Oct 17, 2007
  • 744 Answers
SOURCE: Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Posted on Apr 12, 2009
goofduck
  • 490 Answers
SOURCE: dryer working to long to dry clothes
more than likely the belt needs to be replaced and the unit needs to be cleaned out (too much lint built up in the unit)
Posted on Apr 13, 2009
arikrom
  • 528 Answers
SOURCE: it takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Posted on Jan 01, 2010
Daniel S
  • 4323 Answers
SOURCE: Zanussi TCE7224 Condenser Dryer: Sometimes
Hi
When dryer wont heat or wont turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 10, 2010
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
Drying cycle
The heating element may be worn, or a thermostat switches off the electricity to the element cause a overheating or so.
Jan 02, 2008 | Zanussi ZWF1430W Front Load Washer
Long time to dry
Check drain filter on front of machine and check machine is doing full spin. Regards Advisor
Aug 20, 2007 | Zanussi FJS1225W Front Load Washer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
My zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Mar 06, 2007 | Zanussi TC7114W Electric Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
Top Dryers Experts
