Question about Duplo DF-920 Automatic Paper Folding Machine
Folding mis alignment - Duplo DF-920 Automatic Paper Folding Machine
Hello all, I had met with an accident on Thunderbird 350cc and parts replaced fork & handle bar. But whenever i try to leave my hands while riding at 60- 70 kmph it swings toward right. Please help
Sounds like the frame maybe bent at the steering head...this is a tricky check..The dealership I worked at had a special tool made that screwed into a steering head, had measurements to take at certain places on the frame... (this was 40+ years ago)..good luck
Jul 14, 2017 | Motorcycles
Why does door open when in use anew lock has been fitted but does'nt seem to hold the door in the closed position comes open by it self tumble dryer then stops any IDEAS ?
Take a close look at the installation of the latching mechanism. There may be a slight adjustment that could be made to cause the latch to fully engage. I'm thinking the replacement was not placed in perfect alignment and the latch is failing to secure the door.
Look to see if there are slotted holes at the mounting surface indicating adjustment potential. Look on both pieces of the door latch as the mis alignment could be on either. Also check the door spacing across the top. Is it perfectly aligned or is it lower on one side by a half-millimeter of so indicating a hinge issue? A subtle change in the height of the door on one side could be the cause of mis alignment of the latch.
Mar 06, 2015 | Dryers
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
I HAVE A 97 F250 7.3 DIESEL. THE STARTER IS NEW BUT WHEN I TRY TO START IT IT SOUNDS LIKE THE STARTER IS KICKING IN AND TURNING BUT THE MOTOR IS NOT TURNING. WOULD THE GLOWPLUG RELAY CAUSE THIS?
Don't think so. It sounds like the starter is mis-aligned and not engaging the flywheel. When the starter spins, the gear on the end is supposed to move out and engage the flywheel. Sometimes the springs are bad or there is too much friction on the spiral shaft, but if this is a new starter, more than likely it is mis-aligned.
Sep 06, 2010 | 1997 Ford F250 SuperCab
My Minolta Maxxum 400si film SLR seems to have a jammed shutter and the shutter curtains seem to be mis-aligned (this would be because of the previous owner, not me) but the bottom curtain actually seems...
With the shutter curtain out of place the camera will not function. If it is only out a little you may be able to persuade the shutter blades to fall back into position. If you bend them, or if they are out of the proper tracks then the camera will have to be sent to a repair service for repair.
Nov 23, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Skipping stitches
Common problem is incorrect tension, either upper or lower thread.
Of course mis-threading will cause this or a bent or mis-aligned needle.
Oct 04, 2009 | Kenmore Sewing Machines
Screen is frozen at the green Align Screen. Tried
Here is your drivers link kindly go and get it
http://www.filebuzz.com/findsoftware/Driver_Intex_IT_102WC_Webcam/1.html
Sep 07, 2009 | HTC Touch P3450 Smartphone
1992 Ford Exployer radio wont fold out from the dash
check the way the it is folded check the wires and fuses for grounded wires and mis connected wires to your 1992ford Explorer.
Jul 23, 2009 | 1992 Ford Explorer
Samsung L200
Sounds like your lens has been mis-aligned, if a lens on these types of cameras is jolted or knocked around it will mis-align the lens or take it out of calibration. The best thing to does is take it to a camera shop and have them look at it
May 08, 2009 | Samsung L200 Digital Camera
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
Duplo DF-920 Automatic Paper Folding Machine Logo
81 people viewed this question
Top Duplo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
