Question about Magellan Maestro 3200 GPS
How do I reset GPS to original setting
My GPS is not showing the correct map when travelling outside current region. I tried to troubleshoot and by accident added my home address to Set GPS status option. The problem now is it starts from my home location no matter where I'm - how do I clear or reset to original setting?
  • 544 Answers
thank you for using Fixya.com
click on this site you be directly connected to the manual including to solved your problem how to reset your unit general..
http://www.scribd.com/doc/249380/TomTomONE-Manual
hint go to page 39 of the page GENERAL Reset guide.
Posted on May 21, 2009
How often should my gps be reset if at all?
The only thing you need to do (maybe) is to update the maps. make sure its maps cover the region where you will be travelling, otherwise it won't be of any help.
Feb 13, 2014 | ACR Maylong Group FD-220 Car GPS Receiver
Garmin etrex ledgend c: When track log is turned on, "breadcrumbs" mark the path I've traveled. I don't save the track but the breadcrumbs remain on the unit's map....forever.
Hello
Check both your track and map settings. Make sure that "show track on map" is not selected in your map settings, and in your track settings try erasing all previous tracks.
Hope this helps!
Dec 09, 2010 | Garmin eTrex Vista Cx GPS Receiver
My gps takes me the inner routes avioding high ways....i had to travel to hampton virginia the other day and it took 6hours with the gps but mapquest only took 4hours
LOOK FOR THE SETTINGS/ PREFERANCE SCREEN SEE IF THE AVOIDANCE FOR HIGHWAYS IS TICKED ALSO IF FASTEST SHORTEST ROUTE SETTING IS CORRECT, ASSUMING YOU HAVE UP TO DATE MAPS SHOWING THE HIGHWAYS
Dec 24, 2009 | Tomtom ONE 3rd Edition GPS
Once region is set how do I change it on the megellan roadmate 1212?
By default, the Magellan RoadMate has the region setting for the lower 48 United States. When the receiver is turned on for the first time it may ask you to assign regions. Select the map region you want to use by tapping on the item from the list.
If you are travelling in other regions you will need to change the map region by using the following steps.
1 From the Main Menu, tap on the right arrow to access the second page of the Main Menu.
2 Tap on User Options.
3 Tap on Region.
4 Tap on the map region desired.
The Region option will display the map regions that are available for the Magellan RoadMate you are using.
Also if you want you can download the user manual from this website
visit website
or
download
Hope this helps
thanks
Oct 01, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Map probem
my map on my gps road mate 300 is ereased by my son and now when i try to find or to travel it says no map . Is there any means to reinstal the map? thank you
Aug 13, 2008 | Magellan RoadMate 300 GPS Receiver
How do you get the gps to show depth and markers on the water?
It depends on what model you have. Most chartplotters require a chip with regional chart data. Most Lowrance models use Navionics charts. If you have a chip in the GPS, go to the map screen and press the "menu" key. Somewhere in the map setup menu will be a field where you can specify which chart to display.
For example a Navionics gold chart may cover the entire east coast, but it is broken down into a few sub regions. If you are boating in New England you would select the sub region labeled Northeast. Some of the earlier models didn't name the regions, they used model number for each region such as "XL904G". In that case your best bet is to try each one until you can view the charts in your area. Zoom in to 1/2 mile scale to make sure you can see charts.
If you have done all that and still can't see the chart details, there is also a setting in the map setup menu that allows you to set the level of detail. Make sure it is set to normal, more, or most. If you see a declutter setting on the setup menu, try setting it to off.
Jul 21, 2008 | Lowrance GPS
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Cheers.
Sep 15, 2007 | Garmin Map Source City Navigator
Magellan Maestro 3200 GPS Logo
448 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
