Question about GE GLDT696TSS Builtin Dishwasher
MY SPRAYERS ARE NO WORKING - GE GLDT696TSS Builtin Dishwasher
Volvo c70 windshield sprayer not working
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
Sep 04, 2014 | 2009 Volvo C70
How to fix the wiper spray
The sprayer itself may be attached to the underside of the wiper arm and is removable. Carefully remove the sprayer, disconnect the hose, and turn on the wiper and the washer. It liquid comes out of the hose, the sprayer is clogged. If no liquid comes out, the hose could be clogged, so replace the hose. You need to find the other end at the black plastic manifold that divides the washer flow into the two sprayers. Disconnect the passenger side and blow into in, just in case to unclog it, then try again. If the washer is working for the driver side, that manifold is unclogged.
Soaking the sprayer overnight in vinegar could unclog it., but the sprayer is cheap to buy new.
May 27, 2014 | 2005 Buick LeSabre
Where is the serial number?
The serial number for this is not stamped on any part of the gun it is with the warranty paper work next to the model #
May 12, 2014 | Wagner SprayTech Paint Sprayer. Flexio 590...
Rear windshield wiper sprayer doesn't work but the fronts work fine 2002 jeep liberty limited
The rear wiper has its own pump motor. pull the hose from the wiper and have someone engage to see if there is a clog. do the same at the motor. if bo liquid comes out then its the pump. also check fluid level in reservoir as well as a possible secondary reservoir
Dec 01, 2012 | 2002 Jeep Liberty
Graco Magnum XR5 electric airless sprayer won't start
It could be something as simple as you have the pressure turned down so low it won't appear to be working try to turn the pressure up and see what happens.
The worst thing could be you did not clean the sprayer out properly and now the paint has dried and the shaft is frozen to the packings and the other internal parts of the your sprayer.
Jun 27, 2012 | GRACO INC Magnum XR5 232740 Paint Sprayer
Back windshield wiper is working but no water coming out.front side are working fine.what causes it,not to have water at the back?
Your washer system could be low on water, the pump that pumps water to the rear sprayer could be bad or the connector could be loose, the hose to the rear sprayer could be busted or the rear head could be clogged.
There can be many things affecting your sprayer... goodluck!
Mar 27, 2011 | 2000 Toyota RAV4
Windshield sprayer fuse location in a 1996 subaru legacy
Some of your fuses are located under the hood on the driver's side, right behind the battery. Underneath a black cover. The rest are on driver's side in the car, on the far left side, mounted behind a black cover, to the left of where your left leg goes when driving. Your sprayer may not be working if it is clogged up, common problem. Can you hear the sprayer work? I have 1996 outback and just cleaned out all my hoses and now the sprayer works fine.
Mar 02, 2011 | 2001 Subaru Outback
I have 2 sprayers one is the Roundup Professional Sprayer the other is the all in one sprayer from Roundup - neither of them are working - what am I to do?
Um what do you mean by not working. spray not killing weeds, or sprayer itself not working???
Sprayers clog up if not cleaned after each use, try cleaning the entire sprayer.
Oct 06, 2010 | Roundup "" Weed & Grass Killer
Herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Apr 11, 2010 | Chapin Spectracide Sprayer
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Open Questions:
See all GE GLDT696TSS Builtin Dishwasher Questions
GE GLDT696TSS Builtin Dishwasher Logo
22 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
