Question about Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet
Proscan how to
How do I restart it
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Jan 23, 2018 | Tablets & eReaders
My Proscan Tablet won't connect to CasinoRPG it is always coming up AwSnap, can anyone help me
Hi try this :::: select "tools" & then click "extensions" disable an extension & restart browser ....good luck
Jun 27, 2016 | Proscan PLT 9 TAB 9-Inch Tablet Black
My Proscan tablet is only flashing a blue screen that says "Proscan", How Dow I get it to start up normally??
It is not loading the operating system because it is faulty. You will most likely need to take it to a computer service center for analysis.
Some times the problem will clear by shutting the unit down and restarting it. However you have no doubt tried this a number of times already.
Dec 25, 2015 | Tablets & eReaders
What can I d to factory reset my pros can plt7777G tablet.
Hi Patricia,
You can perform a reset / hard reset to completely wipe out the Android phone this will also remove any passwords and configurations.
Note : To perform this process on your own risk
Step by step guide to reset proscan Android Tablet PLT7777G-Q
Step 1: First, turn off the tablet.
Step 2: Press and hold the power button and quickly poke the reset hole until you see an Android logo on screen.
Step 3: Use the paper clip to poke the hole to navigate until you go in to the Wipe data or Factory reset.
Step 4: Use the power button to select and you should be able to see the screen menu.
Step 5: Select the Delete all user data and restart and it will process it then select restart/reboot after the reset.
Once you have reset the device back to factory settings, all data will be deleted and cannot be recovered.
Or: you can also do this by going into the proscan Android Tablet PLT7777G-Q`s settings>backup and reset and selecting the factory data reset option.
Jan 15, 2015 | Tablets & eReaders
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
How can i get my proscan 9inch tablet to accept adobe flash player?
my proscan 9 inch android 4.4 will not allow adobe flash player i need flash 11, says my device does not support this. is there any way around this, or should i be returning it.
Dec 22, 2013 | Proscan Tablets & eReaders
I cant add apps to my proscan tablet
your proscan tablet has to have internet to add apps
Nov 24, 2012 | Tablets & eReaders
Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet Logo
158 people viewed this question
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
