Question about Ariston Technologies Washing Machines
Washing machine wont spin
My washing machine wont spin. the door lock l.e.d flashes rapidly and the delay timer flashes. it seems to pump out the water and then stops??
    Scholar:
  • 72 Answers
Maybe something is physically preventing the drum from spinning, causing the motor protection to kick in and stopping the machine.
I'd check this out as a first step before calling a repair man:
1) unplug the machine from mains
2) make room between the rubber gasket and the drum for your hand/arm to reach down into the bowels of the machine, in the compartment between the drum and the bowl (or whatever you call it). If you find something strange there, remove it.
I've done this on occasion and have found lots of obstructing objects that don't belong there. Most notably hardware from underwire bras I might add... :)
It is worth a try.
Posted on May 21, 2009
  • Håkan Sterner May 21, 2009
    Also check that the machine get water, sometimes the inline water filters get clogged and this would stop the program from continuing. Some machines also have a sensor in the detergent lid, if it is not properly closed the program will stop.
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
The On-Off door lock LED flashes rapidly at the same time with Delay, Timer and Rapid LED. and it wont start.
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
May 04, 2011 | Ariston Technologies AW129NA 16 Lbs Front...
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and...
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Jul 05, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Water pumping out at a trickle. stops in mid cycle
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Jun 30, 2009 | General Electric WSSH300G Front Load...
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Jun 01, 2008 | Hotpoint BWM12 Front Load Washer
Waterpump won't pump and spin cycle won't start.
one of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Mar 19, 2008 | Frigidaire FWS833A Top Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
