Question about NorStar Meridian M7310 Phone
External Speed-Dial Default Lines
All of our external speed-dial numbers default to Line 4, but we have recently had Line 4 disconnected, therefore, when we use our speed-dial numbers, the operator says the line has been disconnected. How do we change the default line from #4 to another connected line? Thanks!
    Champion:
  • 211 Answers
You have to remove line 4 from appearing on all of your phones.
Login to your system with Feature ** config.
Go to extensions find lines configuration, and set Line004 not in service on EACH extension.
Posted on May 23, 2009
Hello. I have a M7310 Nortel office phone. All of a sudden, the Speed Dial button will not work. In checking the phone, all the speed dial numbers are still programed in the phone, but again the speed dial...
What? They are either programmed or not programmed. If the button is blank, I'm voting for NOT programmed.
If your system is old enough, it's probably lost the backup battery. Ugly things, like pulse dial and only 2 lines are what usually happens, along with losing all of the button mapping but your 2 lines and the default programs of LNR, CONF, etc.
If it's just one phone, there's no magic recall. You'll just have to reprogram it. Same with the system if you've lost everything, but I"d call a repair tech first to fix the battery on the software cartridge.
Carl
Apr 14, 2011 | NorStar Meridian M7310 Phone
KX-Ta824 Speed dialing problem
Panisonictel.com has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
I have a toshiba DKT3512S and need to reset the time, also i would like to know how to do speed dials. Thanks mara
You will have to get into program mode for this. you will have to press this sequence of buttons. Hold*#*#1*2*3*. Password is default to 0000. Program number is 902 then press hold. Press Intercom button for Date and line 1 button for time. If you press Intercom #66 enter speed dial number 10-99 is station speed dial. If you press Intercom #66 and enter speed dial numbers 100-999 will be system speed dial. Hope this helps. I included a site below with program manuals.
http://www.wedophones.com/ToshibaManualsLead.htm
Oct 12, 2009 | Toshiba DKT 3010 Corded Phone
Speed Dial Numbers
You have to go into system programming . Press the feature button then the star key two times and then the password which is 266344 by default . so it should look like this . F ** 266344 and then repeat the password 266344 . now that you are in you look for the heading speed dial numbers . if you need help to find the heading then you can call me and I can walk you through it . My name is Efren and you can reach me at 626-712-5753 m-f 9:00 am to 5:00 pm pacific time .
Apr 13, 2009 | Nortel T7316E 2-Line Corded Phone
Setting the speed dial numbers
Dial Feature *4
Enter the speed dial code (71-94)
Press a line button or a pool button
Dial the phone number desired
Press hold or OK to finish
Nov 03, 2008 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
the intercom button. If you do not specify the external line, the system
5. Press HOLD.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Speed Dial
Feature *4
enter a 2 digit code from 71 to 94
specify the external line by pressing the line button
dial the number you want programed
press hold
Mar 27, 2008 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
202 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
