Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Fireing out carb
I have an 18hp intek plus briggs in my craftsman rider.2001. My wife was useing it yesterday and said it stalled and wouldnt run. I check on it today. It would fire and run ruogh but every other fire came out the carb. I cleaned and check plug, magnito, and checked to see if the key in flywheel was broke. all were fine. What would cause this?
  • mdstupfer May 22, 2009
    it has never been serviced other than change oil and filter
  • 420 Answers
It could be an intake valve that is not sealing due to sticking or burning and in some cases mal-adjusted. When was the last time the valve lash was adjusted?
Posted on May 21, 2009
  • Mike Squire May 26, 2009
    It sounds as though it is out of time which is a little un-characteristic for a non direct drive mower.
    I recommend taking it to a servicing dealer that is familiar with the B&S engines and have the engine checked and serviced including adjusting the valve lash which it is over due for.
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
My B&S 18hp Intec engine on my lawn tractor will not start but it will backfire??? Will not run
You may get lucky and have a sheared keyway on the flywheel . Just a lil off can make a big difference on timing.
Jul 28, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My intek 18hp will only run with choke fully closed.please advise possible problem &solution .the throttle seems to have little impact on the running of the engine
Hi and welcome to FixYa. It sounds like the metering jet in the bottom of the carb throat is clogged.
1st turn off the fuel supply
You will have to remove the float bowl from the carb and then the BRASS jet / orifice. Once removed hold it up to the light.. you should see a pinhole of light thru the jet. No pin-hile = run only with choke. ALSO the nut / bolt that holds on the float bowl has 2 holes in it make sure those are clear.
Before you reinstall the float bowl turn on the fuel and catch it in a spray paint can lid or something similar. It should flow rapidly and stop as you GENTLY raise the float. If no flow then you have a stuck needle and seat or a clogged fuel supply line. Correct same and reinstall the filter bowl. It should run fine after that.
Thanks for using FixYa!
Kelly
Mar 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
222 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
