Question about Campbell Hausfeld 1300 Psi Pressure Washers
What oil is used in the transmission
Changing oil
I have a 2012 Rav4. I had my oil changed and I was told that my transmission fluid is black and smells burnt.I called Toyota I was told that my car's transmission never needed flushed.Is this true ?
It is a myth that trans mission oil never needs changing
All oils oxidise under extreme heat conditions ( and transmission oil reaches very hot temperatures) and bearings, bands and clutches do wear
again flushing is a general term incorrectly used
A transmission oil change generally removes the oil from the pan area but leaves 1/2 the torque converter with contaminated oil
That in turns re-contaminates the fresh oil
Flushing on the other hand is expensive as it require a considerable amount of new oil to do the job It is done with the engine running and fresh oil is drawn in as the old oil is pumped out
so you have to decide to have it changed or flushed as the difference can be in excess of $200.00 dollars BUT the results are also very different
Many manufacturers run sealed transmissions , for the sole purpose of preventing DIY people from putting in the wrong oil and so causing a problem in the transmission
remember that you most probably have a CV transmission
Constant velocity) which utilizers a drive belt between 2 pulleys and requires a special transmission oil as well
The transmission performs similar to the old automatic transmissions but is vastly different in internal construction
Normal period for a change ( depending on speed and operating conditions ) is 60,000miles so talk with an accredited specialist transmission shop to get an idea as to what is a good idea on oil changes
Sep 08, 2017 | Toyota Cars & Trucks
Should I change automatic transmission oil on my 2004 kia sedona?
forget the friends advice
automatic oil should be light tan or cherry red depending on the brand of oil used
the oil should be changed around the 60,000 klm mark and done by accredited transmission shops
If you have a CV-transmission that requires a special oil (not auto transmission oil as they are not automatic transmissions --they have a belt running between variable pulleys which gives the impression that it is automatic but it is not)
May 12, 2017 | 2004 Kia Sedona
How much gearbox oil for mazda cx7 2009 Outomatic
std automatic transmission
got to use the right oil
says 9 quarts approx 8 ltrs with filter change
you may have some left over
never over fill
a full flush not recommended on older transmissions
CVT transmission use different type and colour oil and have a test kit to check oil degradation ...
oil change intervals not done on how many km traveled
Oct 16, 2016 | 2009 Mazda CX-7
What is the proper kind of transmission fluid for a transmission change?
Mitsubishi would love for you to use their oil, lololol. In reality, the proper oil is the oil rating needed. I usually use a good name brand oil and be sure it is that SPIII ATF I guess. I use Hypoid GL4 manual transmission oil which also can go into the rearend too if needed. If replacing the trany oil, be sure to dump the old oil and clean the magnet located on the drain bolt when you dump it. By the way, I use the oil I mentioned in an 86 Mitsubishi mighty max 5 speed. I use the 80-90wt. Might need to warm it up before pumping it into the tranny. Don't over or under fill the trany too.
Jun 02, 2014 | 1999 Mitsubishi Montero Sport
Transmission oil change
I take it you are talking auto transmission. Un do the drain plug in the box sump or if you do not have one remove the sump. replace filter in the sump . replace the sump with a new gasket and refill the sump. IF there is nothing wrong with the transmission and you only want to change the oil the best practice is to take it to a auto transmission shop where they can change the oil with the engine running and this changes the oil in the torque converter as well giving you a complete oil change. IT is more expensive as more oil is used but it changes all the oil and not just a part of the system. If your are talking manual, then remove the drain plug in the bottom of the gear box and when all the oil is out replace the plug tightly and remove the filler plug in the side of the box. Add oil until it runs out of the filler hole and when it stops replace the filler plug tightly. Use the correct grade of oils in both cases.
Sep 08, 2013 | Pontiac Fiero Cars & Trucks
Just need info about changing transmission oil in 1996 Ford Crown Victoria LX. I'm not familiar with type of Transmission oil to use
ford does have their own type you can get it at any parts store just tell them what it's for also at Ford
Aug 27, 2012 | 1996 Ford Crown Victoria
I have hyundai sonnata 2006 4 cylinder. it has just completed 100000km.should i changet transmission oil now.
The transmission oil starts breaking down at 30000miles. Most car dealers change the transmission oil and filter at the second scheduled maintenance service at 60000miles. Changing the transmiosion oil is an insurance for the transmission. Make sure to use the specific transmission oil for your car.
Nov 05, 2010 | 2006 Hyundai Sonata
'93 Hyundai Lantra, automatic transmission has trouble changing up from 1st to 2nd, it tends to rev on a bit, clunks once or twice before changing to 2nd, other gears seem to be ok. Oil levels are ok and...
\'93 Hyundai Lantra, automatic transmission has trouble changing up from 1st to 2nd, it tends to rev on a bit, clunks once or twice before changing to 2nd, other gears seem to be ok. Oil levels are ok and have recently replaced the transmission oil (yes the correct oil was used)
Jan 16, 2010 | 1993 Hyundai Elantra
Oil change
well its always recommended every 3000 miles to change the oil if you are using mobil1 full synthetic oil then every 5000 miles transmission i recommend every 45000 miles 60000 mile should be radiator fluid,power steering,fuel filter if trans hasnt been done then transmission
Jul 06, 2009 | 2002 Volvo S60
Campbell Hausfeld 1300 Psi Pressure Washers Logo
15 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
