Question about WarmFlex Under Floor Warming: 20 ft. x 36 in. 240-Volt Floor Heating Mat
Aube th132 problems. My temperature isn't going up at all. Can someone tell me if it's the sensors? I don't know much about this system... Thank you
Aube th132 problems
The unit is not talking to the sensor. It is most likely the sensor.
Mar 13, 2014 | Hardware & Accessories
Aube th132 problems
You can reset the programming of the comfort setting and make sure that it did not get set at 14C. Here is the manual that shows how to do that.
http://www.aubetech.com/manuel/2/TH132-A-F-AF-230.pdf
Sep 19, 2013 | Hardware & Accessories
I have the aube TH132 underfloor heating system installed. I have programmed the temperature set points to 18c but its over heating to 43c!! I've re programmed it but with no luck!! The icon for when...
This product has 2-year warranty against defects in workmanship.
Aube technologies Inc.
Warranty does not apply to poorly installed ...
Canada 450-358-4600
Manual does not have troubleshoot section.
section 4 includes temperature setpoints by model number.
On-line manual can be word-searched for fine details that might be missed by a visual read.
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that air vents are open to control, so the unit can read correct temperature.
Change temperature Display selector for F or C.
Make sure wires are connected to correct terminals to match your voltage.
15 amp max rating indicates #12 gauge wire for 120Volts. Recommend that thermostat control a contactor instead of direct-wire to heat coils.
Example contactors
http://waterheatertimer.org/H230A.html
Oct 09, 2012 | Hardware & Accessories
I don't know why my microwaves keep beeping and starts the Exhaust Fan automatically every 5 mins. The display says F-3. Please help me with the problem I'll appreciate.
F-3 is usually for the temperature sensor being faulty. What you need most likely is to replace the temperature sensor. This would explain why your microwave oven exhaust fan keeps going off, because your temperature sensor is telling it that it is overheating even though it isn't.
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The timer no longer working. I can only turn it on and off. It's a model that does not required voltage to work.
You posted under Aube in-wall timer.
If this is not your timer, add a comment.
Aube timers have a rechargeable battery that runs timer functions, and timer does not require 120 volts from circuit.
OK, I wrote to Aube about low temperatures affecting their battery.
Aube said, the battery is good down to freezing, and probably lower.
Lower temperatures cause display to slow down and not function, which means timer programs will not work when timer is exposed to cold temperatures.
Manual override would still work, but not programming or display.
So if timer is NOT located inside warm house, for example timer located in unheated garage or shed, then timer will not function in cold temperatures.
That being said, Aube battery is rechargeable.
Battery is not replaceable.
If Aube battery has gone bad, then timer is not repairable.
Intermatic ST01C and EJ500 in-wall timers are also battery operated. Intermatic ST01C and EJ500 battery can be replaced.
Almost all plug-in type timers also have a rechargeable battery that is not replaceable.
Several in-wall timers do not require a battery, but they need power from electric circuit.
To see these timers, plus description how to wire this type of timer:
http://waterheatertimer.org/Programmable.html#Aube
Nov 17, 2010 | Aube Technologies Aube 7-Day Programmable...
Is there an easy to understand user manual for the aube TH132 AF ? Even my father in law can't understadn how to operate the under floor heating on a timer...
http://www.uheat.co.uk/aube_th132_underfloor_heating_thermostat.htm
TH132 is a thermostat for under-floor heating
Go to the website above and download on-line copy of your manual
On-line manual let you read bigger print & lets you break down the steps easier
I am sure by the time this answer reaches you, the problem will be solved
This is true because manuals are frustrating, until you tell somebody it can't be figured out >> which gives you time to rest >> after which the manual makes sense.
BUT I am frequently wrong, and you may be at a standstill
A quick look at the manual.
You can also select which part of the manual is giving you a problem and then I will help you through that specific difficulty
Wiring: I guess the instructions at bottom of manual apply to your model
Your 240Volt hot wires from breaker box connect to terminals 1 & 5
Your two wires supplying power to heat connect to 2 & 4
Pilot wire to terminal 3
Floor sensor to 6 or 7 >> wire from sensor can connect to either pole
The TH132 has two sensors, 1 located inside the TH132, the other sensor located in floor
Set up:
The first part describes 10 buttons (right away you know this is complicated)
There is a brief description of both sensors
Step 1 shows how to configure the start and temp-display switches
Step 2 covers installation of module on base
I guess you hook up power at this point because the display is supposed to light up
This implies that the bottom part of manual should be located more towards the top, and the power-up directive seems to be missing. Bad manual.
Step 2 shows what the display looks like with first power-up
Step 3 tells how to set current time and day.
Step 4 adjust temp setpoints >> floor temp is pre-programmed to 82 degrees
Step 4 shows that you press-and-hold the sunshine or moon button to have it display
The sunshine button is the upper temp setting, the moon is the lower temp setting
Step 5 is operating mode > choose automatic for programming to operate
Step 6 is programming, which carries on with about 24 steps
If this is your problem area, let me know
Now the manual suggests you make a chart of your programs
Other programmable devices don't work when there is a conflict in programming
Wow I see the TH132 is 'equipped with a proportional adaptive controller..' that carries a two year warranty. I'm sure you'll rest easy knowing that.
Reply back with the specific trouble area, and we'll get it going for you.
Oct 21, 2010 | Aube Technologies Aube 7-Day Programmable...
I do not understand the manual that came with my TH132 control unit. Can some one guide me so that I can set the heating for different times for Mon-Fri and different times for the weekend?
Aube technologies has a page with thermostat manuals
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=1&app=1
Thermostat page shows 3 models for your TH132 (toward bottom of page)
Click the model number and it opens a second page
The manuals for each product are conveniently located on that second page, toward the bottom, along with a description of your product.
In my opinion, Aube (Honeywell I think) website is way ahead of the curve for customer convenience
Most other electric device websites have manuals located on a different page than the product
A lot of sites, like Leviton, have no manuals at all. Lose the manual, and you have to call their customer service like in the 1980's
Aube must want your repeat business.
Oct 17, 2010 | Aube Technologies Hardware & Accessories
Our controle module TH132 A/F/AF goes blank every time the heating systen is supposed to be activated
I have also had the same problem with 2 units. I have been in touch with Aube who say they have identfied a problem with the back unit which they will have fixed in " a few months time". My suggestion would be to contact them for a replacement later on this year
Oct 27, 2009 | Aube Technologies Hardware & Accessories
1995 Audie A90 Coolant Temperature Sensor replacement
It's located under the hood, driver side, upper engine area, mounted on rear of engine block behind cyl. head.
Dec 09, 2008 | 1995 Audi 90
WarmFlex Under Floor Warming: 20 ft. x 36 in. 240-Volt Floor Heating Mat Logo
558 people viewed this question
Top WarmFlex Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a WarmFlex Hardware and Accessory Expert? Answer questions, earn points and help others
