Question about Measuring Tools & Sensors
Briggs stratton wiring diagram
No fire to the plugs when the motor is turning over. only when the key is released
5 Suggested Answers
  • 225 Answers
SOURCE: I have a 20 Hp briggs & stratton motor it will
have you checked the oil ?some units have an oil sesor,that if oil level is to low shuts the unit down to stop damage to unit.
Posted on Jun 21, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 583 Answers
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Posted on Oct 25, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
I have a petrol golf cart wont start
Brian, If engine is of overhead valve type and engine turns over with plug out and will not crank when plug in or turns very slow, the problem is probable valve adjustment required or decompression release faulty on cam shaft. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kohlerengines.com/maintenance/basicTroubleshooting.htm
briggs and stratton ohv hard start crank fix
How the compression release mechanism works on Briggs and Stratton OHV...
HOW TO ADJUST VALVES FIX HARD TO START Lawn Tractor with OHV Briggs Engine...
Aug 16, 2016 | Cars & Trucks
Wiring diagram for a briggs & stratton model 313777
Go to Partstree.com and put in the model number. You will find some nice diagrams there.
Mar 07, 2015 | Briggs & Stratton Garden
Wiring diagram
the wires you have are a ground wire a charging wire if you have a charger and the coil plug wire on a short blocked motor you might have a secondary stop wire to
Mar 23, 2013 | Briggs & Stratton Briggs Stratton...
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
703 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
