Question about Epson Printer
Dell 922 printer. No paper in machine but it tells me I have a
Paper jam. Do you know what is wrong?
Thanks,
  • 544 Answers
can you please open again the cover of your printer and double check maybe there was still paper inside even a tiny paper will caused a problem.
thanks.
Posted on May 21, 2009
My Dell 922 printer will not grab the paper anymore. The rollers are turning but nothing is happening,
The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 29, 2011 | Dell 922 All-In-One InkJet Printer
Dell 922 saying there is a paper jam
First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
Good luck.
Thanks for using FixYa.
Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
My dell 922 printer say there is a paper jam but there is no paper stuck in the machine
check the full inside of the machine, even a small piece of paper in some of the spooler inside can cause the printer to malfunction.
Dec 07, 2009 | Dell 922 All-In-One InkJet Printer
I have a Dell all in one 922 printer When I try
If your device is out of warranty, I'd suggest to clean the rollers again completely. What I mean is to remove the scanner lid and back cover, then clean all of the rubber rollers gently with alcohol and swabs.
Jun 14, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
922 Dell Printer Problem
either the gears of the paper feeder are cracked or misallignewd and needs to be replaced or readjusted or the sensor which detects the paper in the tray is broken. so you r facing this error. please check it out. it will solve your problem.
Oct 26, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 all in one paper jam
maybe following this list of suggestions might be of some assistance?
May 03, 2008 | Dell 922 All-In-One InkJet Printer
Printer won't take paper
did you look in the back of the printer?
unplug from power?
Dec 17, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All In One Printer cartridge carrier jammed
unplug and plug back in this should reset printer so carrige will move
Dec 05, 2007 | Dell 922 All-In-One InkJet Printer
Epson Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
