Question about Tappan MEF500 Electric Kitchen Range
Code f11 on tappan electric oven - Tappan MEF500 Electric Kitchen Range
2 Suggested Answers
  • 794 Answers
SOURCE: Tappan Millennia Electric Oven #316065306---
Hi rich750,
The F1 error code description is an electronic oven control failure. The easiest way to fix this error is to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Dec 14, 2014 | Frigidaire Kitchen Ranges
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Error code f11
I do not know what the error code f11 means on your appliance but I do know that if you cannot find it in your manual you will obtain the information you require from the manufacturer or a reputable dealer or service engineer. If this error code relates to an open door and you are satisfied the door is properly closed then the switch that closes the circuit that permits your oven to operate is not operating. This may be due to the oven door seal stiffness being just enough to keep the switch contacts apart or it may be due to dirt or grease preventing a clean electrical contact being made.
Jan 17, 2012 | Tappan 30IN ELEC IGNa Oven
F11 error code - frigidaire electric overn
Disconnect power for 30 sec, then turn it back on
Dec 09, 2011 | Frigidaire Ovens
What does an F3 code mean on a Tappan oven/electric range? The lock on the oven door is sticking out not allowing me to shut the oven door all the way.
This is your oven temperature sensor on your Tappan Oven.
T
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
Oct 19, 2009 | Tappan 30IN ELEC IGNa Oven
Our electric tappan dual radiant baking and roasting oven is beeping and giving an f1 message
Hi gracie7773,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Aug 02, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Millennia Electric Oven #316065306---"F1 comes up on digital clock and oven is beeping".
Hi rich750,
Hope it helps.
Jul 30, 2009 | Tappan TGF320 Gas Kitchen Range
F3 code beeping
F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Nov 27, 2008 | Tappan MEF500 Electric Kitchen Range
Need owners manual for Tappan TGF334BCWb oven
Looking for Owner manual for a Tappan Gas Self Cleaning Oven Range - Model No. TGF 365BEWB
Nov 14, 2008 | Tappan TEF242 Electric Kitchen Range
Tappan MEF500 Electric Kitchen Range Logo
37 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
