Question about American Microsystems - M5900I-0101-0 - Aml, M5900, Portable Data
Aml m5900 is frozen
Only button that works is scan wont power down or esc to menus. need a way to reset it. taking battery out doesnt do anything except stops scanning
I recently got a used ZTE 2958 and it wont advance past the google sign in screen due to a previous reset. No info known re former owner. Suggestions?
You need to do a factory reset.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Back up all data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Jul 22, 2016 | ZTE Cell Phones
Phone frozen up wont do anything not even coming on
You could try a reset.
Hold both the Home and Power buttons until the iphone begins to start.
It should take about 10 seconds.
It this does not work, your battery may be low.
Connect charger and try reset again.
Additional help from Apple support page.
If your iPhone iPad or iPod touch doesn respond or doesn turn on
Feb 21, 2015 | Apple iPhone Cell Phones
Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Apr 02, 2014 | Proscan 8 4GB Android 4.1 Tablet
How to reset m7220
There is a barcode you can scan to return the unit to factory settings. (included here) or If you call AML they will E-mail a .pdf to you. Also included in this message:
(1-877-842-3990 as of 1/23/15)
reset-m7220-ryj5jtttbma1c5cx4ef5i5ba-5-0.jpg ____________________________________________________
2000 year old roman coin gift sets for $10 at etsy: http://www.etsy.com/shop/coinrelics
Sep 18, 2012 | American Microsystems Aml m7220 m7221...
Screen has frozen, can't turn it off or move anything, just not working.
There are a few things you can try to resolve this:
  1. Hold down the power button for up to 15 seconds to reset the unit.
  2. If that doesn't work, you'll want to try changing the power connection to the unit. If you don't have it plugged in to the cradle or the usb cable, plug it in. If it is plugged in, try unplugging it.
In the event it stays frozen, eventually the battery will drain. When the screen goes blank, you can then plug the unit in and recharge it. Let it charge for at least 30 minutes and then try to power on the unit.
Mar 03, 2011 | Tomtom ONE GPS Receiver
Iphone has frozen. Won't take calls, won't turn
hold on the power and home buttons until the screen goes black, once black keep holding the buttons until you see an apple logo then release, this is a soft reset. if this doesnt work plug into itunes and when the computer recoginizes it click restore. this will delete everything on your phone and take it back to the way it was when you bought it.
May 10, 2010 | Apple iPhone Smartphone
Pavilion dv6700 locks up; mouse & keyboard frozen;
If you take the battery out and unplug the AC power the laptop will shut off.
Aug 15, 2009 | HP Pavilion dv6000z Notebook
Frozen
Hold down the power button for 5-7 seconds and it will shut the laptop off. If that doesnt work, remove the battery from the bottom of the laptop and disconnect the AC adapter.
Apr 24, 2008 | IBM ThinkPad T20 2647 Notebook
Frozen
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 01, 2008 | Audio Players & Recorders
Zen v plus frozen screen on no buttons working
Zen V is dead
if that doesnt work try
Dec 20, 2007 | Creative Labs ZEN V Plus MP3 Player
American Microsystems - M5900I-0101-0 - Aml, M5900, Portable Data Logo
78 people viewed this question
Top American Microsystems Computers & Internet Experts
David Payne
David Payne
Are you an American Microsystems Computer and Internet Expert? Answer questions, earn points and help others
