What is OE on WD-12331AD (direct drive 7/3.5kg)
4 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: My LG intellowasher 7,5kg WD-
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
  • 170 Answers
SOURCE: Washing machine LG Direct drive
CL means control lock should be a button or bottons on your machine that you press and HOLD to unlock the control panal...so the childern don't mess with your washer....Good luck
Posted on Feb 01, 2011
  • 170 Answers
SOURCE: "CL" appearing on my LG
CL is for control lock /look at panal closly should be botton or bottons you press and hold to release the control panal...Good luck
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off
see if the water pump making that noise or is broken
should look something like this one
May 18, 2016 | LG WM Washing Machines
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
My LG Washing machine is not spinning. It also comes up with OE. Can you help
Check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
The most common problem with spinning on this model machine is the tub bearing. Normally it would be very noisy when it did spin.
Massive job to replace it.
Dec 06, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
The picture is very dark
Sounds like your lamp/bulb is about ready to die. Here is a google shopping list for some replacements if you choose to DIY. http://www.google.com/search?q=Mitsubishi+WD-60735+replacement+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=Mitsubishi+WD-60735+replacement+bulb&hl=en&client=firefox-a&hs=XxY&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=k7KtTZP4A4jk0QGYm6jHCw&ved=0CHwQrQQ&biw=1366&bih=650&bav=on.2,or.r_gc.r_pw.&fp=30e0fb8dc28dda8
Also if you need help on the DIY just come back. But a detailed reinstall can be found in the manual starting on page 75 which if you don't have can be found here:http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf. Also on that page is a part number and phone number to get replacement direct from Mitsubishi. Good Luck!
Apr 19, 2011 | Mitsubishi WD-60735 Projection Television
Feb 01, 2011 | Washing Machines
Washing machine LG Direct drive 7, 3.5kg WD 12331AD It has CL sign on it i cannot operate the machine how can i clear that nad get the machine to work?
Feb 01, 2011 | LG Washing Machines
My LG intellowasher 7,5kg WD- 8016c is flashing the letters OE Can you please tell me what this means
Dec 25, 2010 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
My wahser displays CL - it won't wash anymore
It normally on the LG means your washer is protected by the Child lock function.
it either takes the option and the temp button at the same time for 3 seconds or You'll see a smiley face between the wash and rinse buttons. Press the rinse and wash buttons for a few seconds at the same time and the child lock (hence smiley face) will switch off - Not to familiar with this model but this should work.
please rate me.
Apr 19, 2008 | Washing Machines
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
