Question about Refrigerators
Westinghouse virtuoso fridge
Virtuoso RJ525V-R fridge acting like freezer,-5 degrees whereas external temp reads +6
xalint1
  • 152 Answers
SOURCE: fridge not cold freezer ok
More then likely your problem is that its not defrosting correctly in the freezer and the ice has built up behind the panel and not allowing the cold air down into your refrigerator.
Posted on Aug 22, 2008
  • 5 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
  • 4793 Answers
SOURCE: westinghouse virtuoso fridge door wont shut. it is
SPACER WASHER ON PIN HINGE GON AWOL/REPLACE IT..if can lay unit over to get to screws on bottom hinge of unit underside, awkward/heavy, not on your own please ,this mother is heavy.........
Posted on Feb 08, 2010
SOURCE: westinghouse virtuoso fridge freezer manual
where is filter located for water and ice block dispencer on a 2003 model
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: i have a westinghouse virtuoso
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 29, 2010
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
Fridge is freezing....
The way you've stated your problem is confusing? The temperature is the freezer should be 5 degrees F or below, preferably at 0 degrees F. The refrigerator side should be anywhere from 34 - 38 degrees F, What exactly is the problem your having, fresh food not cooling but freezer works ok?
May 07, 2012 | Westinghouse Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
I have a Westinghouse RV525V-R*4 Virtuoso Fridge (Electronic Display) which beeped twice and gave an error today on the display - Cnn Err. The dispay was showing the temp in degrees F. Tried everything...
I wasn't keen on the 48hr period so I tried a work around. I disconnected the front display which reset the alarm in question. To disconnect the display you have to disconnect the wires that supply this power. This is located underneath the top plastic hinge cover for the freezer. Remove the cover
May 31, 2011 | Westinghouse Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse virtuoso fridge door wont shut. it is hitting at the bottom. model number RJ525V-R. You have to lift the door to shut it.
Feb 08, 2010 | Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
I have a westinghouse upside down fridge what tempereture should it be for freezer/refrigerator? cos its pretty to cold like bit of ice goes in the meat packages.
The fridge should be between 2 and 5 degrees C or 36 and 41 degrees F and the freezer should be between -18 and -25C and 0 and -13 defgrees F. If you cant get the temp right then call a service engineer asazp.
Sep 10, 2009 | Westinghouse Refrigerators
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
