The first time I switched on my new Rancilio Silvia, it made a loud noise, and it still does everytime, also the machine starts to shake a little bit. What could be the problem? Thanks
My Silvia was doing something similar to this after no less than 2 weeks of operation.
Not
being too worried about the warranty for just opening the case and
looking inside......I did so. Be careful. Unplug as you remove various
panels. Just don't touch anything with wires. You can see your problem
if it is the same that I had.
Remove water res. Remove SS top.
To view the pump, I had to remove the SS shield separating the
reservoir from the boiler area. You will find the pump attached to the
bottom of the chassis. It is supported by a rather flimsy rubber mount.
Mine was collapsed to one side.......and the pump was literally banging
against the chassis. Yes.....that will rattle your cups sitting atop
the machine. To prove that your pump is not held securely in its mount,
actuate the ON switch and observe the pump. Use only short burst of
power when viewing your pump as you are NOT
pushing water thru the assembly....and of course, all those electrical
shock hazards that exist.
If it is shaking side to side......that is your problem.
I
took a piece of hot water pipe insulation that I had out in the garage
and cut it to the length from pump fitting to exterior wall of cabinet.
I think that might have been about 4.25 inches (I fixed this problem
over two months ago and can't remember the actual length). The
insulation piece is very light and holds the pump quite securely in
place precluding the side to side vibration and the terrible noise. The
split in the insulation allowed for the water line to be held securely
as it comes out of the pump.
Reinstall all shielding parts, etc.......and you should be back on your way to minimal pump noise espresso shot pulling!!
I need to order a part for the silvia rancilio macchine per caffee. I need the filter hoder, two cup...
(More)
I need to order a part for the silvia rancilio macchine per caffee. I need the filter hoder, two cup filer, one cups filer, ground coffee press & coffee measure instructio manual. where can i get these parts?
Rancilio Silvia coffee machine worked once making two coffees.... despite on light being there it is...
(More)
Rancilio Silvia coffee machine worked once making two coffees.... despite on light being there it is now not heating water at all. Tank is full with water.
Last time used was spent trying to perfect steaming milk.
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and...
(More)
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and is between the on/off switch and the heating element. In the diagram it is described as "thermostat 165º". The actual stat is marked "Ty 80-R Campini, 16/250~ T210. If available, please quote full price and postage, and terms. Thanks, Colin
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
