Question about Kenmore Refrigerators
Ice build up in freezer
Cold spot
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
  • 17 Answers
SOURCE: ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Posted on Feb 10, 2009
lagringa15
  • 9 Answers
SOURCE: freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Posted on Aug 04, 2009
  • 15 Answers
SOURCE: Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Posted on Dec 15, 2009
SOURCE: GS6NBEXRSOO model whirlpool gold 2005.
My freezer is working but my freige is not working what should I do
Posted on May 01, 2011
The fridge has stoped workingbut the freezer is fine
if it starts working ok after the defrost then you might find it will build up ice again.
There might be a fault with a small device called a thermister that senses the ice build up for the defrost controller.
What most likely is happening is the ice build up freezes the fan that blows the cold air to the fridge compartment.and around the freezer.
May 14, 2017 | Bosch KGU6655
We have the Kenmore model #795.78309.800 and the freezer drawer track keeps freezing up and make it almost impossible to open the freezer. This just started the other day.
the most common problem is a bad sealing door ,when the door is closed it is not supposed to let warm air in and cold air out ,but if the seal is faulty then the opposite happens and this causes the build up of ice,take a good look at the door seal a good way of finding out if this is the problem is to run your fingers around the seal when the door is closed for a while if faulty you will find a warm spot where the cold and warm mix causing a warm spot.adrian,,,,,,,,,,
Aug 13, 2010 | Kenmore 22.4 cu. ft. Bottom Freezer...
Smeg Fab40 fan stopped working - there is a build up of ice at bottom right freezer.
There is an upgrade kit for the FAB40 to prevent ice build up which falls under the warranty for the FAB40. I've had it installed and it basically replaces the entire back of the inside of the freezer. Following the upgrade, my FAB40 would ice up completely, plugging the ducts to lead cold air to the fridge below. You can spot this syndrome by the water dripping throught the grate at the top of the fridge compartment. This is melted ice from the freezer ducts. SMEG has now sent their top guy, a drunk and pretty rude guy who replaced the whole backside again, and I'm hoping it will improve.
The bottom line is, SMEG is just ****. Very, very expensive ****. I invested about 10.000 dollars in SMEG equipment three years ago, and every single piece of machinery in my kitchen has broken and needed repair during that time. I deeply regret having bought stuff from them and next time I will definitely go with something different.
Mar 31, 2010 | Smeg FAB40PS Top Freezer Refrigerator
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
GE GBS18HBRAWW / ICE BUILD UP IN DRAIN LINE/TROUGH
Check for a blockage around the through area from the freezer to the refrig. or something such as a jug of milk that you keep in the same loacation time after time. if this jug or what ever stays in this area that can cause a cold spot and keep that area from getting warm enough to let ice thaw.
Feb 10, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
