Question about Frigidaire PLHS267ZA Side by Side Refrigerator
PLHS267ZA is leaking water from the bottom (freezer side)
Have a PLHS267ZA Frigidaire and noticing that water is dripping from the bottom of the freezer side. It does sometimes look like it is coming from inside the freezer and seeping out. I have taken everything out and ensured that there are no blocks but still nothing. What other things should I be looking for and what else could it be? Not having a lot of luck finding a solution for my model easily. I also am not noticing it doing it at set times like if I am getting water or if it is making ice...seems to be random.
  • 496 Answers
I would look under the fridge for a drip pan that might be full, so when it defrost it overflows the pan and runs on the floor. If not that you must have a blockage somewhere in the drain line that runs to the drip pan. Take out the shelves and take off the plastic panels to access the drain and drain line, pour some warm water down the drain to unplug it.
Posted on Jan 03, 2014
5 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: side by side gallery ...water leak
  • it sounds like the water valve is not closing fast enough.
  •  this will cause the ice-maker to overflow a little.
  •  your ice-maker may have an adjustment on it to control how long it keeps the water valve on.
  • it should be a screw with a + and - sing on it. it may be under the ice-maker plastic cover.
  • if it keeps doing it then you may need a new water valve.
Posted on Jun 29, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
farfield
  • 462 Answers
SOURCE: FRIGIDAIRE SIDE BY SIDE WATER LEAKING FROM BOTTOM OF FREEZER DOOR
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
First lets decide where your leak actually is.
Areas to consider:
This is mostlikely a stopped up drain pan. A cold area that is not suppose to be cold likewhen you have a freezer coil that is suppose to be defrosting and is not... Seebelow for a more complete ideas list of things to check under Possibility.
The drain pan drain line is themost common. Inspect it and repair as needed, maybe its just a wrapper over the exit hole of the pan.
Some more Possibility's:
1 There is a drain that carries away the water under the cooling coils. Thesecoils are in the freezer section. Its most likely clogged or froze up.
2 The ice maker could be letting water leak all the way down look for an icy trail from the ice maker area.
3 Door gaskets are not sealing especially on the bottom of the door. Thisallows warmer air into the fridge section and it is condensation on floor underthe crisper.
If you check all of these items and still cant find it please post back andtell me what you did find. So I can help you more. Please rate me as much aspossible as Im trying to keep my average up and do the things that willactually educate and help people.
THANK you for using fixya and good luck..
Posted on Mar 22, 2009
  • 4793 Answers
SOURCE: ice in bottom of frigidaire side by side freezer
clean out the drain hole with clorine bleach/blow out any gunk manually defrost unit.no hot water. no fault of siting.just a blocked vent...
Posted on Feb 09, 2010
My refrigerator leaks water out the bottom when I use the water dispenser in the door.
water line has a hole. probably from a mouse chewing on the plastic tube. Another possiblity the plastic tube was pulled on and pulled out of the compression nut / connector.
Feb 07, 2014 | Frigidaire PLHS267ZA Side by Side...
FRS26KF6EMB
The water valve sounds like it may be leaking and the drain hole is plugged if this is a side by side the drain is in the very bottom back. sounds like it is actually a two problem situation you have. watervalve bottom back outside frige and drain in the back bottom of freezer.
Sep 23, 2012 | Frigidaire PLHS267ZA Side by Side...
My Frigidaire leaks water on the freezer side. A puddle appears every day on the floor in the front of the freezer. Inside the freezer on the bottom there is ice buildup. I think a drain must not be...
The defrost water is supposed to drain through a tube located in the bottom rear and flow into the flimsy plastic evaporation tray located inside the bottom trim panel. The tube may be clogged. The tray may be cracked or broken.
Feb 01, 2018 | Frigidaire PLHS267ZA Side by Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Jan 06, 2009 | Frigidaire PLHS267ZA Side by Side...
Water leaking from freezer.
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 12, 2008 | Frigidaire 22.6 cu. ft. Side-By-Side...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
171 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
