Question about Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range
Bake element wont heat up - Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range
3 Suggested Answers
  • 10865 Answers
SOURCE: My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
Posted on May 31, 2009
  • 106 Answers
SOURCE: baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
Posted on Nov 21, 2009
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 19, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
The bottom bake element does not heat up. I replaced it with a new one, still wont heat up. all other functions work. broil, top element heats up on bake.
Did you test the old element before you replaced it? If you did, then you would know that there is some other problem such as a bad wire connection or the bake setting control . Now you need to test each aspect of the wiring and controls that feed this element. macgivor
Dec 27, 2009 | Kenmore 94210 / 94211 / 94212 / 94214 /...
My oven DOP340 wont heat up and the fan doesnt
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Oct 05, 2009 | De Dietrich DOP390 Pyrolytic Electric...
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
BREAD WONT BAKE
Chances are 80% that the heating element has blown. This is due to the fact that a heating element has a limited life span because of the great amount of heat it generates. I would first check or have the element checked at your local repair store before looking for any other problems. It's possible that the thermostat which controls the element has blown, but it's more likely to be the element itself.
Let me know if this solves your problem.
Best wishes,
Graemevm
May 19, 2009 | Kitchen Appliances - Others
Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range Logo
12 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
