Question about Inverter AIMS Power 2500 / 5000W
Aims 5000w inverter
I have an aims pwr/nv5000w inverter. it will not come on because overload light comes on in split second. is there a bad rely to the fan maybe?
    President:
  • 1,723 Answers
Try shutting down the load completely, then power up the inverter with no connected load. Then bring a little on at a time and see what happens.
Posted on Jul 03, 2009
Having issues with my laptops when the AIMS 600W Pure Sine Inverter turned on. As soon as I exit the cab of the vehicle with the laptop the issues resolve themselves.
You will need to either mount the inverter further from where you are using the laptop or shield it enough to get the laptop out of the "arc" of the power generation.
Now the problem: The inverter does produce heat so you can't mount it in an unvented box.
You are dealing with the same problem as the high tension power lines, that has a radiation zone, and you either need to cut back the zone or move it further away.
If it the inverter was modified in any way, then they might not have gotten all the shields back correctly.
Sep 10, 2011 | Inverter Aims Pure Sine Wave Power...
I have a problem with my inverter in that when i load,it cutts off, and at that moment it is only one lighting point that is on,it tells me that their overload and fuse blown,what do i do?
I have an Aims 2500 W inverter that was damaged from an accidental connection of voltage from the grid. i replace all of the IRF260n FET transistors but it is still shutting down as soon as it is turned on.Can some one tell me if those FET must have a drive at the gate. Before it will work
Feb 17, 2011 | Inverter Aims Pure Sine Wave Power...
I have a Aims Inverter PWRINV5000W with all the lights on but no output at plugs.
Hi!!
There is a fuse or thermal device for the AC outlet(s) protection, is either next to the outlet or same place but inside the unit. The cover need to be removed to change/reset it.
Let me know if you found it. Good Luck!!
Dec 08, 2010 | Inverter Aims Pure Sine Wave Power...
I have a Westinghouse LTV-32w1. The inverter is lighting the backlights for only a split second. Screen is still visible under an external light. The board is getting and holding it's 24 volts from the...
16 transistors did not go bad at the same time, of course. The inverter's driver IC has an overload sense circuit which causes the inverter to turn off.
There are too many possible reasons why an overload can happen and half of them do not involve shorted components.
Your easiest solution would be to replace the inverter. Unless you want to get into the repair business it might as well be the cheapest one.
Hope this helps.
www.coppelltvrepair.com
Oct 17, 2010 | Televison & Video
When it's started the engine revs hard as if it's powering something whilst nothing is connected. after a few seconds the overload light comes on & the engine settles down but the overload light stays...
in checking my manuals their is a rectifier that controls the 12 volt side this can be bad even though it is for the 12 volts some times the gen needs a back pulse witch acts like a exciter that kick the power in you can replace this part i do not have the part number i'm sorry but you can get them from electronics stores the part will be black 1x1x3/8 inch with a mounting hole in the center with 4 wire studs replace and try this first if the issue is not solved then the inverter unis is bad unfortunately this is a solid state sealed unit encased in a hard gel that hole unit will need to be replaced in order to cure your issue i hope this helps
Aug 29, 2010 | Coleman Powermate Powermate 5000W...
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Sep 09, 2009 | Honda Electrical Supplies
Overload light on Aims 5000w inverter
try to disconnect all cables from front and back, then turn the unit on and let all the stored charge drain and reconnect and test...make sure the unit grounded
Sep 06, 2009 | Inverter AIMS Power 5000 / 10000W
Aims Inverter PWRINV5000W Installation Manual I just went to install it and no manual in the box
Here you go- contact info for Aims. They can provide you with a manual. Good luck....gary
AIMS Power Contact Information:
9736 S. Virginia St. STE A
Reno, NV 89521
Tel: (775) 359-6703
Fax: (775) 359-6753
e-mail:
sales@aimscorp.net
techsupport@aimscorp.net
customerservice@aimscorp.net
Jan 10, 2009 | Inverter Aims Pure Sine Wave Power...
Aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Inverter AIMS Power 2500 / 5000W Logo
489 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Clint Millett
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
