Question about Equator EZ 2512 CEE Front Load Washer / Dryer
Drain and reset EZ 3612 CEE - Equator EZ 2512 CEE Front Load Washer / Dryer
  • 249 Answers
SOURCE: EZ 3612 CEE Equator front load washer
Its the main drum Bearings!or else if your lucky it might be a spring off! or broken! up on top remove top to see!! it s not the belt
Posted on Dec 13, 2007
  • 131 Answers
SOURCE: Equator EZ 3600 CEE Front Load
Most likely, the door latch isn't functioning properly.
Posted on Mar 31, 2008
SOURCE: EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Posted on Apr 05, 2008
SOURCE: Handle
I order mine online from appliancedesk.com. I have one ordered now. It is on backorder. When you install new, be sure to mark position of door inserts, just in case they separate and you have to figure out how to reposition them.
Posted on Apr 23, 2008
  • 37 Answers
SOURCE: when drying rubber burning smell from inside Equator EZ 3612 CEE
If you are still wanting to know the reason, it may be that the door gasket has warned off and may need to be replaced.
Posted on Feb 26, 2010
Equator Washer dryer combo......door wont open. Finished a funky cycle drained but wont open? :(
You will have to follow the drain out procedure and then the reset procedure.
Please see the link :http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Be careful, if you try to open the door by pulling the door handle too hard it may break.
Do let me know if this resolves the problem or else I may suggest something else.
Mar 26, 2010 | Equator EZ 3612 CEE Front Load...
The machine is not drying, and is not heating the water
The 2 thermostats and the temperature sensor may have to be replaced. You may contact appliance desk technical support for proper troubleshooting and then order the parts required from them itself.
You can find their contact information on their website - www.appliancedesk.com
Feb 11, 2010 | Equator EZ 3612 CEE Front Load...
No power when plugged in. Any ideas? Equator model # EX 3612 CEE
Is the door light coming on, it may be that the control board has gone bad, let me know on this.
On the other hand for quick resolution you may contact Appliance Desk Technical support for proper troubleshooting.
You can find their contact information on their website www.appliancedesk.com
Jan 29, 2010 | Equator EZ 3612 CEE Front Load...
When drying rubber burning smell from inside Equator EZ 3612 CEE
Apr 04, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Handle
Apr 09, 2008 | Equator EZ 3612 CEE Front Load...
ChicagoRandy,
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
i think the belt of the motor or the motor it self..... bad is sound produced only when something is loose due to over used... i suggest that to replace belt or motor...
Nov 09, 2007 | Equator EZ 3612 CEE Front Load...
Equator EZ3612 CEE
If you still need assistance on this let me know and I can provide you with the procedure for the same.
Sep 15, 2007 | Equator EZ 3612 CEE Front Load...
Dryer isn't working
You have a burnt out thermostat. Order one from Equatoronline.com (or whatever it's called, and order the thermostat element for it. It worked for me the first time.
Dec 12, 2006 | Equator EZ 3612 CEE Front Load...
Equator EZ 2512 CEE Front Load Washer / Dryer Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
