Question about HP Photosmart C6180 All-In-One InkJet Printer
2 line phone and hp 3309a all inone.
I have a 2 line phine in an office. I have the line in going to the hp all in one (fax), then out the second line port back to the phone. When I try to dial on the phone, it doesn't let me complete the number and tells me the phone numbers is wrong. I also noticed that with both devices hooked up with a splitter the same thing happens. Also with the hp just plugged into the line makes the phone have a repeating dial tone before it goes steady.
    Genius:
  • 1,605 Answers
If you having problem with a splitter, then the porblem is at phone comany end, not the fax machine or your phone, I would call the phone company to check out their line.
Posted on May 21, 2009
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Hp office jet 5610 all in one printer--- am I able to fax without hooking up to a computer if yes how- thanks
All the HP office all-in-ones fax without computer hookup, simply place the fax on the load tray face up until you see the window state that the original is loaded. Then on the number pad dial the fax number you want to connect to, once that is done...press the black fax button and the machine will dial the number, once a connection is made the fax will feed itself through and complete. The only connection needed is an outgoing phone line. Just make sure that the phone line is in the right socket on the back. You will see icons by the sockets, the one with the phone icon is for a line to go to a phone headset....this is not the socket for the main phone line, ise the other one that says "line".
Jun 27, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer is hooked up to a phone line that gives a different ring when a fax come in. I have been able to fax documents,,can't receive them and no longer get calls on the line because when i pick up the...
Perhaps you can talk to your telephone service about setting up a second line just for your fax sending and retrieval. There must be some type of deal they could give you..especially if you are a loyal customer.
Feb 26, 2010 | HP J4680 Office Jet All-In-One Printer
The fax will not answer even though I have it set to answer after 2 rings. It is on a dedicated line. Help!
There is a check box that must be checked in order to enable automatic answering.
Also, you have to have the phone line plugged into the Officejet machine
Oct 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I cannot receive faxes, I have misplaced my owners manual of course!
Check the phone line with a regular phone.
Do you have digital phone service?
Jan 30, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Greetings my hp office jet its not faxing nor receiving faxes. it says no dialing tone
At a guess, I would say your phine line is either dead, or you have the line connected in to the incorrect socket. The phone line needs to be plugged into the socket that has an 'L' next to it. Check this first. If this is plugged in, check the line to the wall socket to make sure it is plugged in. If all this is good, press the hook button on the front of the unit, if it has one. You should hear a dial tone. If there is no hook button, get a phone and plug it in, if there is no dial tone, get a telephone tech in to check your line. If there is dial tone and you still can't fax. the unit has a faulty modem and will need to be replaced.
Being it a HP ink jet, should this be the case. throw it out and buy a new printer as the printer cannot be fixed because HP do not supply spare parts for their inkjet printers.
Gremlin11
Dec 13, 2008 | HP Officejet 4355 All-In-One InkJet...
Faxes office Jet K60
You have to have either a dedicated phone line just for the fax --or-- pay your phone company approximately $2 a month for a service called Distinctive Ringtone. This service will ring a certain way when you have an incoming fax. You will then configure your fax machine to pick up when this distinctive rington is heard. The ringtone is usually two or three quick rings. Your fax machine's settings will have this setting.
Unfortunately, you can't just plug your fax machine into your phone line and start sending/receiving faxes. Look through your fax machine's manual regarding the distinctive ring service. Good luck!!
Oct 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
Hp L7580 fax machine
set up the fax driver in windows printers and faxes menu with the calling card prompts. you can use commas between sets of numbers for 2 second pauses. such as (example) 9,,1800callmci,,,2,,3,,cardnumber,,,4digitpin,,3685551212, - in this fashion, you can edit the fax number here before sending the fax.
Sep 24, 2008 | HP Pavilion dv6000z Notebook
HP Photosmart C6180 All-In-One InkJet Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
