Question about Singer 2263 Mechanical Sewing Machine
Where is the feed dog switch? I need to lower them.
5 Suggested Answers
SOURCE: feed dog
don't know how i did it but it is working now. thanks anyway.
Posted on Apr 02, 2008
wcbotha
  • 92 Answers
SOURCE: How do I lower the feed dogson the Singer 140Q?
Next to the bobbin holde there is a latch , move it up or down to lift or let it down. wcbotha@yahoo.com
Posted on May 12, 2010
Zenqi
  • 208 Answers
SOURCE: I own the singer advance
The 7442 does not have feed dogs which can be dropped. You need to use the "Darning Plate" which came with the accessories.
http://www.singerco.com/accessories/manuals.html
Posted on Nov 01, 2010
SOURCE: I need to drop the feed dogs on my singer confidence 7463
here is a link for a free manual, if the feed dogs can be lowered
then it will show in the manual, just click on the link
http://www.singerco.com/uploads/download/546_7463_efs.pdf
Posted on Dec 13, 2012
I have a singer touch & see sewing machine, I need to change for quilting but there are no visible switches to lower the metal times under the foot.CAN ANYONE HELP I'M ON A DEAD LINE. THANKS,
I don't know this machine but in most machines the feed dogs are normally lowered from a switch beside the bobbin case behind the door of the bobbin case.
Jun 14, 2015 | Singer Sewing Machines
How do I raise or lower the feed dogs
The older machines had the switch directly behind the needle mechanism. Reach behind the machine and see if you can feel it. It should be a slider type of switch. The real old machines did not have the capability of raising and lowering the feed dogs, so an index card was taped over the dogs so that they would not interfere with free motion. Good luck!!
Dec 06, 2013 | Singer Sewing Machines
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
I need to know how to lower the feed dogs on my Huskystar Viking E10
There is a switch on machine to raise feed dogs up/down. Remove any extension table to locate it because many of these options are located in the back of machine & hidden by table! Jimmy :)
Apr 07, 2012 | Husqvarna Sewing Machines
The feed dogs are not pulling the fabric
A couple things can cause this. Very lightweight and slippery fabrics and too heavy of fabric. Lowered or worn feed dogs, not lowering the presser foot lever....
Check your manual for a switch to lower the feed dogs. If that is in the correct position, you may need to have the dogs replaced. Contrary to popular belief, they do get worn.
Good luck
Feb 05, 2011 | Singer 3116 Simple
Can the feed dogs be lowered? And need a manual....
Manuals will be difficult to find because the companies limit themsleves to the amount of spares they make, open the slide plate and see if there is a drop feed lever, if not you may have raised plates instead.
Mar 06, 2010 | Janome 8080 Computerized Sewing Machine
How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Aug 25, 2009 | Janome Memory Craft 5700
Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Oct 27, 2008 | Husqvarna Viking 1
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Singer 2263 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
