Question about Pentax K100D Digital Camera
Camera reverts always to 2006 date when power turned off
The display upon the camera being turned off always reverts to the initial date 2006
    Problem Solver:
  • 14 Answers
Hi There. 1st go to menu Then Go To Memory Then select Flash. This will hold the date when taking the battery out. Av A Good Weekend Regards Alex
Posted on Aug 07, 2009
Canon powershot sx100is. Error 24 on starting and camera turns off. Can view pictures already taken.
some dry wash lens,display & camera.mother board clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone past.so work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Canon PowerShot 600 Digital Camera
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Dec 14, 2010 | Insignia NSDSC10A Digital Camera
How to fix my DSC-W70..it always say turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Nov 13, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
I can't on or off my l19 camera and the lens is always coming out.display is blank.
Issue with Ic Prologic.. Fail to initiate ..Camera got drop.. Board defect need service ... Try To...Take Battery off for 5min then put back on the battery then try to set date & time ..Sometime your have to set date and time before the screen apear ...if it so change your Battery memory inside the unit check on the main door battery for slot mini battery for memory
Sep 30, 2010 | Nikon COOLPIX L19 Digital Camera
Date has reverted back to2006
Press Menu and select the Setting Menu. Navigate down to "Date Adjust" and press Right-arrow, and the Date Adjust screen will appear. Navigate around and change the settings. Press OK when done.
If you've misplaced your manual, you can download one from the manufacturer's web site at http://www.pentaximaging.com
Feb 03, 2010 | Pentax Optio M20 Digital Camera
For use with compatible battery only
1. Ensure that you are using either Battery Model # NP-BG1 or NP-FG1 with the Camera.
2. Try Initializing the Camera as follow (Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera):
a) Press the Menu button on the Camera.
b) Then, select the SETUP menu and select the SETUP 1 option of the Camera.
c) Then, select the Initialize option to OK.
3. If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Camera takes 3 pics instaed of 1
Power up camera, press Menu >> Initialize >> OK
Provide date and time upon rebooting camera.
This will solve your problem.
May 14, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Pentax K100D Digital Camera Logo
93 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
