Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
My pedrollo pump, pumps water for a while and goes off by itself. i have put it off (electric switch) and wait for time say 5min and put it on again. it works for a while and goes off again so i have to do the cycle again and again until i get water to the tank above
    Champion:
    Scholar:
  • Hayward Expert
  • 239 Answers
It sounds like the pump is tripping the overheat relay. might be time for a new pump. depending on how far the 'tank above' is, you might not have enough pump to push water there.
Posted on Mar 17, 2016
2 Suggested Answers
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    What oil goes into a Pedrollo Dm30 N
    Read the cap on the oil it will either say 5w-30 or so so.....
    Aug 23, 2016 | Cars & Trucks
    My water pump stopped working
    More details are required to analyze the problem. Is there water available to the pump, does it run but no water etc. etc.
    Jun 21, 2016 | Pedrollo PJ3015-CF N/A 1-1/2 HP High...
    Why water pump fail
    See previous answer. (more details required)
    Nov 09, 2014 | Pedrollo PJ3015-CF N/A 1-1/2 HP High...
    When turned on you can hear a buzzzing, like electrcicity going into the pmp then pump heats up and trips its saftefy switch. Motor does not turn.
    I am assuming that this is not a brand new installation. If it is, go to http://www.femyers.com and download a manual for your pump.
    If the pump has worked properly in the past, what seems to be happening is that the motor is locked up and the built in thermal protection is correctly protecting the motor. Or if by "safety switch" you mean the circuit breaker is tripping, then the following still applies.
    The pump impeller may be jammed with debris, or the motor bearings may be worn out, causing the rotor to jam and stop rotating. Also a possibility - the seal between the pump and the electric motor has failed, allowing water into the motor and causing a short circuit which trips the breaker.
    It is probably time to call the repairman, or replace the pump. Don't keep trying to turn on the motor; it will not fix itself and you may make things worse.
    Remember, these pumps must be primed with water first before first use. Look in the Operating Instructions manual.
    Mar 24, 2013 | Myers Pump QP10-3
    Our old sump pump went out and I purchased a Little Giant pump with a remote switch. I attached the switch to the pump, attached pump to drain line and put the pump in the basin. It started pumping...
    The rs-5 switch is supposed to turn the pump on at 6 inches to 10 inches of water from the bottom of the switch and shut the pump off when the water gets to 1 inch to 4 inches from the bottom of the switch. Sometimes the pump takes a while to prime itself the first time it starts up. The noise at the end of the cycle is not unusual either.
    Is water coming back to the pump causing the switch to close?
    However, going on & off almost immediately is not right. Is the switch installed in a specific location that it is designed to fit on the pump?
    It does sound like the switch is going back on at too low a water level.
    Also, make sure it is not a rs-5LL for low level. Even this should not allow the pump to go on and off.
    Gary
    Dec 14, 2010 | Little Giant Rs-5 Remote Switch
    Flotec Model: FPS172 - Not Turning On - Click to the Pump
    that peice you described is a check valve and it is required to sustain prime..if you dont have one please get one. otherwise when the pump shuts off the water drains from the pipe. you may also need to reprime your pump by putting water in the pump from a point in the top feed
    Jun 07, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
    Whirlpool dishwasher ADP905
    Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
    Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
    Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
    179 people viewed this question
    Top Hayward Pool & Spa Experts
    Jay Finke
    Jay Finke
    Bill Jordan
    john h
    Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
