Question about Euro-Pro Dressmaker 998B
Bobbin won't pick up in my singer 2662 - Euro-Pro Dressmaker 998B
    Problem Solver:
  • 13 Answers
Make sure that you have the correct needle and that it is in the correct postion.
Posted on May 27, 2009
Needle still moves when filling bobbin
something is broken, or slipped out of place. take it in for repair. While you are at it have it cleaned, checked and retimed if needed.
Jan 19, 2013 | Singer 2662
Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Jul 14, 2012 | Singer 2662
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
How to thread the bobbin
Are you trying to thread the bobbin for winding or for sewing?
For sewing, make sure the needle is fully up and then release the bobbin cover plate. Insert the bobbin so that the bobbin rotates counter-clockwise. Pull the thread through the slot at the center-front of the bobbin case. Hold down the bobbin with a finger then bring the thread to the left and through the slot on that side. You should here a clicking sound when you pull on the thread. Leave 6" of thread free and replace the cover plate. Refer to the manual (page 12) for pictures.
Many Singer sewing machine manuals are available for sale or download here: http://www.singerco.com/accessories/instruction-manuals . The direct link to the manual for the 2662 is here: http://www.singerco.com/uploads/download/429_2662_efs.pdf . See page 11 and 12.
If the bobbin thread isn't feeding, clean the hook and surrounding area. Then with the presser foot down, retry. If you aren't hearing the clicking sound when the thread is pulled, you may need the bobbin tension adjusted. There is a small set screw for the adjustment but it's really easy to damage the threads. If you still have a problem, the bobbin case or shuttle race may need to be replaced (See http://parts.singerco.com/CPpartCharts/2_2999/2662.pdf for the parts breakdown).
I hope this helps.
Oct 28, 2011 | Singer 2662
The needle thread will not pick up the bobbin thread. the bobbin mechanism turns but it doesnt catch the thread.
Most of the time, it is because of the needle. Try a new needle and make sure that the flat side is facing the rear. Hope this helps you,
Oct 27, 2010 | Singer 2662
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Top thread is loose
Your needle thread tension is too tight or the bobbin tension is too loose. If it is the latter try turning the bobbin case tension adjusting screw clockwise abot a full revolution.
If that does not work there is more than likely a bit of lint behind the tension spring, so carefully remove it and clean it out.
Jul 06, 2009 | Singer 2662
Singer 2662 winds bobbin only half full.
there is an adjustment on the bobbin winder. Just bend the little spring flap that rides inside the bobbin while winding. Bend it up a little. The flap being pushed up is what releases the shut off
Jan 05, 2009 | Singer 2662
A horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Jan 05, 2007 | Singer 2662
Euro-Pro Dressmaker 998B Logo
222 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
