Question about GE Spacemaker JVM1640SJ Microwave Oven
Locate fuse on a G E spacesaver microwave JVM1640BJ03
2 Suggested Answers
  • 19 Answers
SOURCE: where is the ceramic microwave fuse located on the
Its on the PC board of the noise filter
Posted on Feb 14, 2010
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    GE spacesaver xl just died. No fan, no lights, no power. Where should I go to repair? I live in Las Vegas
    Might want to check the 20A fuse by the power supply before you haul it somewhere and they charge you a service charge for a cheap fuse...
    Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    The microwave GE spacesaver is not working. It
    TAKE MICRO APART PHILLIPS HEAD SREWDRIVER LOOK FOR A FUSE DOWN WERE THE PLUG COMES IN OR ON THE RIGHT HAND SIDE.iF THAT DOUSNT SOLVE IT TRY TO TIGHTEN ALL THE SCREWS BE CAREFULL YOU DONT HAVE TO TIGHTEN VERY TIGHT. THANKS FOR ASKING Troy Lawton
    Jan 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Spacesaver #JUM 2050BH001not heating
    HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
    (((The fuse is located inside the unit along side the magnetron)))...
    Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Read the question
    Dear FixYa:
    Just to let you know, I'm a general contractor in the state of michigan.And after I didn't hear from you
    I just made a phone call to reasure myself on my question, because it's been a while since I installed
    kitchen cabnits.Almost every spacesaver cord is located on righthand side.
    May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    What size are t top mounting screws on the GE JVM1350 spacesave
    You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
    General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
    A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
    This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
    Here's a picture of three screws:
    Apr 05, 2009 | GE Microwave Ovens
    No power, model jvm1640bj03
    The below statment is refering to your manual which also contains the wiring diagram.
    Microwaves:
     Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel
    http://www.geappliances.com/service_and_support/faqs/
    Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacesaver doesn't heat
    if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
    Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    27 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
