Question about Kodak Office Equipment & Supplies
Replacing carriage belt
Kodak Esp2150 has a broken carriage belt. Is it replaceable?
  • 4 Answers
SOURCE: broken carriage belt
Yea they do http://www.everprint.com/online/simdetail.asp?partno=C4557-40049 I think that would fit.
Posted on Aug 03, 2007
713printech
  • 32 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Posted on Nov 19, 2008
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
gpcomputer01
  • 137 Answers
SOURCE: the belt that moves the printer carriage is broken.
The best way to find a replacement part is to find a non-working printer of the same make and model. HP's are very common and by searching the major ebay or craiglist website you will likely find one. Otherwise, post on one of the possible sites that you are looking for a non-working printer.
Posted on Sep 18, 2009
  • 123 Answers
SOURCE: carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Posted on Apr 15, 2010
Printerhead loose
Hi. Love Kodak, the printed being loose can only mean one thing the clip is broken. After you removed the ink did you remove the head? If so why? Let's try something, going to look at my Kodak printer. Ok so there is a grey tab that holds the top of the head. They put a bullseye looking sticker in the middle if the head. That's the only place you need to push to secure the head. It should make a clicking sound. If you don't hear that click the tab is broken and the carriage needs tho be replaced cheaper tho buy new. Do a visual check FIRST. Look at the carriage look on the top to see if you see a tab. Could be grey, or green right in the middle of the head. If you don't see it, may be gone. Sorry.
Apr 08, 2015 | Kodak ESP Office Equipment & Supplies
I have an ESP2150 with an error message of printhead loose or missing. I checked print cartridges, I replaced print cartridges, I re-installed software and drivers.....I still receive the same error...
Unfortunately, trying to diagnose a printer without actually looking at the printer is a little like trying to diagnose a car engine over the phone. But, from the sound of it, the problem you are having is not exactly pertaining to the print "cartridges" but the print "head" which is the part of the printer that actually introduces the ink to the paper, and is actually part of the tray the ink cartridges fit into. Here is a picture of it:
This print head is able to be removed and replaced if needed. It may be something as trivial as being loose. You can remove it from the printer and reinstall it to make sure it is seated correctly. Here is a link for instructions on Kodak's website on how to uninstall and replace the print head:
Installing and replacing print head.
If the print head is either damaged or worn out (which can happen) you can replace the print head, which I just did a search online for one and it appears the print head is only around $35.00 to replace it. Here is a link to where I found a replacement print head:
Kodak Print Head Replacement for ESP2150
I hope this helps.
-Nathan
Sep 26, 2013 | Kodak ESP Office 2150 All-in-one Printer
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
Hp psc 2175 all in one carriage belt is broken and cannot find replacement
Carriage belt is not a user replaceable part. Hence you cannot replace it by yourself. This unit should be repaired by an HP authorized technician. Please contact the nearest service center to repair it. But I think the repair cost is close to the price of a new printer.
:) Dr Tony
May 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
The print cartridge will not move
There is a "belt" (with pulleys at each end, and the carrridge in the middle) that pulls the carriage from edge-to-edge.
If that belt is broken, or the clamp that connects the belt to the carriage is broken, the carriage will not move.
It's cheaper to replace the printer, and responsibly recycle the old printer, than it would be to try to repair the printer.
Jan 05, 2010 | HP DeskJet 5650 InkJet Printer
The belt that moves the printer carriage is broken.
Sep 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Print carriage problem
I have replaced the belt many times. I think you have to repair your printer in service center.
Mar 18, 2009 | Epson Stylus Photo R200 InkJet Printer
Print head carriage drive belt failure.[hp deskjet 710c]
there is a rubber belt that moves the head from left to right if its broken it needs to be replaced or if its just got loose open the sides of the printer and then refit the belt there is a small section given in the back of the carriage where the belt fits.once u will open u will get the section easily.
Nov 20, 2008 | HP DeskJet 710c InkJet Printer
Broken carriage belt
Aug 03, 2007 | HP 270 Copier
27 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
