Question about Sharp AQUOS LC-60LE640U 60" Class HDTV
Sharp aqous flashes twice fast and the twice slow but won't power on
  • 225 Answers
SOURCE: sharp 37 inch aqous tv
If the blinking light seems to be blinking in a pattern, then it is an error code. The end result in any case, is the main power supply is not functioning properly, or the backlight power supply has a problem.
Posted on Nov 13, 2008
SOURCE: sharp Aquos will not power on. OPC flashes green
I had it picked up to be fixed on warranty. Downside is I'm out a TV for a week.
Posted on Nov 23, 2009
  • 102 Answers
SOURCE: need a power cord for 37 in. sharp aqous
If you do not want to buy a power cord from Sharp, you should be able to take the existing cord to an electronics store like "The Shack", formerly "Radio Shack" and find a replacement.
Posted on Jan 09, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Sharp Aqous 52' opc &
Hi patricia_597,
Unplug the unit from the outlet, then while unplug, press and hold the power on button for one minute to drain the voltage and refresh the boards...
Try to open again and see if the symptoms remain the same...
If yes, the power supply board produced an out-of-regulation condition and disable the unit. The most common caused of this symptom is the leaky/dried filter electrolytic capacitor in the output of the power supply section. It will drop the voltage from normal and trigger the blinking of the led light. It will not power up unless isolated the faulty parts.
Leaky capacitor sometimes has a bulged/dome at the top but not all. Dried capacitor has no physical indication of fault and looks new and in good condition but actually not. You must have a capacitor checker to determine its condition and pinpoint the faulty one.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qulified technician to isolate the symptoms..
Also check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back panel because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 25, 2011
  • 8457 Answers
SOURCE: My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Posted on Feb 24, 2013
Led Tv will not turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Sharp Aquos Televison & Video
Sharp lc-60le650u blink codes
Different model number in the link below but I would assume they're the same fault.
(D_POW. Digital 3.3V failure. Power failure details (Flashes slowly twice and flashes fast 3 times. > DET_D3V3(36pin) failure (L). Digital 3.3V is not applied. If error is detected during start-up or operation, the power is turned on again by polling.)
Electro help SHARP LC 40LE810UN LC46LE810UN LC52LE810UN LC60LE810UN HOW TO...
Apr 02, 2014 | Sharp Televison & Video
Sharp Aquos, no picture or sound, power light flashes 2x fast, then 2 slow, repeats
Two flashes of standby light indicates a fault to its main board. If you wish to get more details about the blinking codes to Sharp TVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
Aug 19, 2013 | Sharp Lc60le640u
Tv flashing lights
Blinking codes to Sharp TV is described in detail by this site. Check it. http://electronicshelponline.blogspot.com/
May 03, 2013 | Televison & Video
Half a screen on my sharp aqous
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 28, 2012 | Sharp 60" Aquos LED Smart TV - LC60LE640U
SHARP AQUOS LC-52D64U TV WITH NO POWER
I had one that was doing the same.   swapped out a back light inverter board... fixed it.  this doesn't mean that my fix will be your answer. to help find which one is of the 2 sides is bad..unplug power to the board one side at a time & half the lcd will fire up.  good luck
Feb 26, 2009 | Sharp Aqous LC-26D5U Television
Sharp lc 20sh1e lcd tv funny picture
Do you still have this, I need a part myself and having trouble sourcing parts?
Mine immediately goes into standby mode and the screen just shows a white flash. I'm sure its just a power issue.
notallbad1@yahoo.co.uk
Nov 27, 2007 | Sharp Aqous LC-26D5U Television
Sharp AQUOS LC-60LE640U 60" Class HDTV Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
