Question about Dryers
Maytag Dryer MDG400BWW
Dryer works but won't stop after cycle completes
frankgant
  • 250 Answers
SOURCE: Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Posted on Jul 08, 2008
WRMtech
  • 70 Answers
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Posted on Feb 26, 2009
wheelshot
  • 102 Answers
SOURCE: maytag dryer stopped working in middle of cycle
I think that the most likely thing that has happened is that the cord has shorted at the terminal block. Disconnect the power from the wall and then pull the cover off the back of the dryer and I think that you will find the problem there. It will be obvious.
Posted on Apr 02, 2009
mrfixit3667
  • 262 Answers
SOURCE: Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Posted on Jan 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Maytag Performa
Hi and welcome to FixYa, I am Kelly
The wiring diagram is here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28505914&pkw_=basket&model_id=46651&NewWindow=1
Possible causes...
1. The heat selector control L-1 ((RED is input power)) to C, to the safety themostat
You should read C of the heat selector control to terminal 3 of the motor switch.
ALSO you should read terminal 1 of the heat selector control to terminal 3 of the motor switch.
2. The 377K ohm resistor
3. Motor switch terminals 3 - 4 (You can bypass this by having someone squeese the brown disk on the back of the switch) Or jumper it
4. Timer Heating element Power from terminals H and R.
Make sure you have 230 VAC input power on the terminal block where the power cord connects L 1 to L 2 (outside 2 terminals) If you only have 115V across L1 and L2 reset the circuit breaker. If you still do not have 230VAC inspect the wall recepticale.
Thanks for choosing FixYa,
Kelly
Posted on May 27, 2011
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
