Question about Goldstar Microwave Ovens
It is running, but doesn't heat the food.
I have a Goldstar microwave model no.: MV1610WW. It isn't heating the food.
  • genlee8 May 22, 2009
    tryin to see if it's worth fixing. i was told it could be the magnatron.
  • John Snow
    John Snow May 11, 2010
    Are you able to test the transformer or the big cap inside with a Volt/Ohm meter. Or do you just need help with might be wrong and weather or not it may be worth fixing?
    President:
  • 788 Answers
I had the same thing happen to my microwave and the Magnatron was the bad part. There are some things that you can check and I would be glad to help. I bought the parts for around $70.00, but mine was a built in unit.
Let me know, I will help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
Posted on May 22, 2009
  • 3 Answers
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try "cooking" a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Posted on Jan 15, 2010
This problem could be attributed to one of 2 reasons:
a. The most common is a defective magnetron. LG provides a 8 years warranty on that part and it is best to call their service to get this fixed free.
b. The control card behind the front panel has a defective relay that sends power to the magnetron. Unfortunately this will require the replacement of the entire board as the relay is not easy to find.
Hope this helps.
Posted on Feb 18, 2010
Microwave not heating food model MA795B
1 door interlock
2 diode
3 magnetron
4 heat censer
5 dry joint on relay on timer board
6 Re: Jeff
Apr 12, 2012 | Goldstar Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
I have an old Goldstar microwave (MV1140T) that just stopped heating. The fan still works but the food won't heat up. What can I do?
The problem is caused by a bad magnetron, "common problem" or the high voltage capacitor and diode, all three work together to heat the food. The repair cost for parts and labor will be high enough to consider buying a new microwave oven.
Feb 23, 2011 | Goldstar MV-1501 Microwave Oven
I have a Goldstar microwave and it is not heating up the food. It is running the lights are on the tray is rotating but the food is not heating up at all.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101//./.
Jun 24, 2010 | Goldstar MV-1526 Microwave Oven
My Gold Star Microwave Oven MV1610WW Stopped Heating. It turns on but does not cook.
heatman101[p]]][p
May 31, 2010 | Goldstar MV-1526 Microwave Oven
Still operable
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 30, 2009 | Goldstar MA-1011 Microwave Oven
Microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
Feb 03, 2009 | Whirlpool GH8155XM Microwave Oven
I have a over the range microwave and I need the support bracket the holds the unit up. where can I get one. model number is goldstar MV161OWW is there anywhere where i can order? and it there a...
That model should be MV1610WW.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Sep 25, 2008 | Goldstar Microwave Ovens
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
529 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
