Question about ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip Cortex A8 Android 4.0, 4GB
My daughter's zeepad will turn on but only to the screen that says "android". it will not get past this stage. I don't see any reset buttons or a way to access inside the unit to find one. What do
My daughter's zeepad is charge and will turn on but only to the dark screen that says "android". the white line will go through the letters but that's all the unit does. it will not get past this stage and engage with the home screen for her to use. I don't see any reset buttons or a way to access inside the unit to find one. I can hold the on/off switch to get it to shut off and turn back on, but that does not reset it. What do I need to do to get it to fire up again?
    Master:
  • 645 Answers
I will give you the instructions to do a hard reset for the tablet.
Once you do this, you will lose all the data on it and will be just like you bought it. The process is listed below.
Press and hold both Volume buttons and the Power button simultaneously. An Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate. Select "Factory Data Reset", press power, choose "Yes" from the menu and press the Power button again.
Posted on Jun 06, 2017
sasurichard
SOURCE: my zeepad 7.o android will not pass the first screen showing zeepad alone.
Am having problem to open up my tablet, when i powered it the icons don't show up for me to unlock it.but it shows the wifi signal and the screen picture i put on.
Posted on Feb 22, 2013
SOURCE: My Zeepad 7.1 Android screen is cracked how do i fix it.
mi tablet se me descontrola la pantalla
Posted on Mar 15, 2013
  • 21 Answers
SOURCE: how do i reset a zeepad
To reset your zeepad you must reload the firmware to it. For instructions go to
www.zeepad.net
Posted on Mar 21, 2013
wwhitney67
SOURCE: i cant remember pass word to my zeepad
I have tried to do all of that and everytime I click a link to download the firmware it comes up page not found.
Posted on Aug 26, 2013
radbmx2000
SOURCE: zeepad does not open
can't get netflex to show picture.
Posted on Dec 29, 2013
When I power it on it will not go past the screen that says Zeepad 7drk. I tried hard reboot. Same screen.
More than likely it is a hardware failure or loose internal cable (eg. Motherboard to screen cable). You can try a factory reset, but doubtful it'll work.
May 30, 2015 | ZEEPAD 7DRK Dual Core 4.2 Red Android...
Hard to read
Tablest have different screen cofig parameters. Look for it in your Setting menu item.
Apr 24, 2015 | Tablets & eReaders
How would i fix the Wifi on my Zeepad? The Wifi will not work at ALL i have done 2 factory resets
I had the same problem. On a Hisense tablet. My daughter fixed it she didn't give up her secret but she downloaded an android firmware app. I believe that may have solved my problem. Believe me I tried everything before she took it home
Apr 06, 2015 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Why when I turn on my zeepad screen is blank battery is fully charged the green man shows then blank screen?
Hi, try a Hard Reset!
Normally, you have to hold one of the volume buttons down while powering on the device(try them one at a time). If you get a screen that says something about download, try the other volume button.
Once the device has booted to the "special recovery" menu, this is controlled by one of the volume buttons to scroll through the options and the POWER button acts as an enter key. Be on the lookout for an option that says something about "restore factory settings" and select that!
Oct 18, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
How do I reset my Zeepad 7.0 tablet to factory settings?
1. Power of the device.
2. Now,Hold down both volume+ and power button simultaneously, you should get an android on its back opened.
3. Press both volume + or - to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Aug 10, 2014 | ZeepadTM 7" Zeepad 7.0 Andoid 4.0...
Tablet turns on shows zeepad then android and wont turn on
someone told me that when that happens that I must have blown one of my cores
Jul 09, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Why when i turn on tablet android picture appears then black screen
When you turn it on, what should appear is a little lock that you slide down to unlock the screen. If you are getting a blank screen there is probably something technical wrong with your zeepad. I would contact the company,particularly if you are still under warranty. I have had mine almost a year and have had no problems with it. When not in use, I keep it plugged in to keep it charged up. Have you charged it the full 8 hours before using?: Other than that, I am at a loss as to your problem. Wish I could be more help.
Jul 02, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Why isnt my zeepad pink 7.0 staying on white screen i turn it on?
So, now you've become a robot.. Throw it in the river and buy fishing pole.
Jun 12, 2014 | ZEEPAD MID Android Tablet 7 Inch WiFi
ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip Cortex A8 Android 4.0, 4GB Logo
74 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Frank Russell
Frank Russell
Da Doc
tony wahlman
tony wahlman
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
