Question about Kitchen Appliances - Others
Oster error message
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
I'm after replacement parts for my oster versa 1400w blender preferably in australia .
when you order parts it goes by model number, from what I can see there are several different model #'s for the Oster Versa,
BLSTBV-RV0-000 and BLSTVB-000-000.
try here, type your model # in the search area at the top.
Oster Blender Parts
or here,
Oster blenders lids blenders jars caps at Goodman
or here, under parts & accessories
Oster Parts Accessories Oster
I haven't found any where in Australia to get them, you may just have to get them on line.
Mar 05, 2015 | Oster Blenders
I have a older model Oster bread maker I cant find the model. I brought it from Salvation Army and I need a manuel
Oster manuals are not the easiest to find; here are three; hope one is is for a model similar to yours. If you can find your model number on the botton or back might be able to assist further.
Thank you for using FixYa!
CKSTBRTW20 - Oster® 2lb. Expressbake® Bread Maker
http://www.oster.com/manuals/MANUALS/CKSTBRTW20_43_33506787.PDF
5838 - Oster® 58-Minute Expressbake® Breadmaker
http://www.oster.com/manuals/MANUALS/005838-000-000_ENGLISH.PDF
Deluxe 2-Pound Bread & Dough Maker
http://kitchen.manualsonline.com/manuals/mfg/oster/deluxe_2pound_bread_dough_maker_p_n_101017.html?idRes=2148332
Sep 14, 2011 | Oster 5838 ExpressBake Bread Maker
Oster bread machine manual
Hi and welcome to FixYa, I am Kelly.
You did not mention a model number so I guessed. Here is the manual for the 2 LB machine:
http://www.oster.com/manuals/oster/005838-000-000_English.pdf (58 minute machine)
This is for the other machine:
All Oster manuals are on this page:
http://www.oster.com/ProductManuals.aspx
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Microwave Ovens
When I plug in my Oster 6248 toaster oven, it flashes error
This is caused by a bad contact on the heat sensor located on the top inside the oven...now if i could juste find the replacement part...
Mar 14, 2010 | Oster Toaster Ovens
My oster 3071 rice cooker ''E2'' error
it happened on my oster 3071 the error e2 just appear the only that i did was open it and I found out that the blue wire which is connected on the lid is cut so i just reconnect the wire and stick it together using souldering iron and presto it is good as new again
Jan 17, 2010 | Oster 3072 20-Cup Rice Cooker
I have an oster toaster that worked for about 8 months, then just recently it shows this error (err) aftr toasting for a min. do you know what i can do?
It sounds like you have the same problem as the Oster 6248 typically develops. The fix is to avoid ever buying anything made by Oster again, because it's all the same ****, made in China, just more overpriced.
Jul 14, 2009 | Oster 6239 Toaster Oven with Convection...
Oster Digital Convection Toaster Oven
Not A solution but I had the issue with a new oven and the factory just replaced it with a different model, My web searches found LOTS of problems like yours and it seems my model oven was discontinued even before I bought it from walmart.
Jun 12, 2009 | Oster Toaster Ovens
My toaster keeps beeping and comes up with an error message can you help
I just called Oster Service and the said to plug in the unit, hold the start button for 10 seconds and unplug the unit. My oven reset before I was able to try this, so let me know if this works for you.
Dec 08, 2007 | Oster 6235 Toaster Oven with Convection...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
