Question about Home
Shower mixer topliss repairs
Very low pressure from the brand new shower head. Great water pressure everywhere in the house, just VERy low pressure in the shower. How do I increase the shower head pressure from the mixer?
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
  • 81 Answers
SOURCE: Low shower head flow from Delta R1824 shower
Try exchanging the Delta head with one of the other shower heads you are happy with if you haven't already done so. No change in the flow means it's not in the head, and change means it is.
If it is in the head, since you are on a well and not a municiple water supply, you might consider removing the factory install flow controll device located just below the threaded area that mounts to the shower arm. These inserts can be a real bugger on some heads and each one is a little different than the last. The trusty nail often works well.
Your body sprays, I believe, are factory fixed at something like 2.2 gpm and non adjustable.
Also consider for a moment a garden hose with trigger spray head on it. When you squeeze the trigger the water will shoot out a certain maximum distance. If you were to take an ice pick and poke a hole in the hose, that maximum distance will be slightly reduced. The more holes in the hose the less the maximim distance. Correspondingly, the more holes you poke the less distance each hole will squirt because you have the same pressure and volume of water but more exit points.
A monitor has a flow rate of about 6 gpm at 85 psi which is pretty average for shower valves. If your other showers have only one exit point(i.e. one head) and the R1824 has 3 with the same pressure and volume, the garden hose illustration can also explain the volume change as well.
Posted on Jun 01, 2010
  • 7 Answers
SOURCE: new shower head, we have VERY LOW water
Typically with shower heads, my rule of thumb is.... Greater the surface area, the worse the pressure. If it is a multiple setting shower head, try a different setting or try a smaller shower head.
Posted on Jun 25, 2010
agent91
  • 2100 Answers
SOURCE: shower head
There is a California water saver on it that can be removed, just a little piece of plastic that covers the opening. Why do you have low pressure? Are you on city water? Well? Jet pump? Turn up the pressure cut off. Check it out.
Posted on Jun 26, 2010
Testimonial: "took out plastic..works!! Low pressue on city water, very old lines and on top of a hill!"
packrat1948
  • 528 Answers
SOURCE: low water pressure from shower
Replace or clean the ball. Go new they don't cast much and trying to clean one out is a pain in the --
Posted on Feb 08, 2011
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
What could cause the loss of hot water pressure in sink and shower but works fine everywhere else in the house
A calcium build up in the nozel heads or pipes from some not so lovely water. Did it happen gradually? There is a filter in the side of electric hot water systems that needs replacing once in a while but that would affect all the pressure.
Feb 26, 2015 | Home
What's wrong with a leaking shower head following new boiler and how do I fix it?
The valves are leaking. It's not the shower head itself. Sometimes shower faucets require special tools to service the valves. If you have thought about new shower valves, now would be a good time to replace. Repair may be half the cost of installation of new. In other words, plumber's time to repair or replace is about the same. Get several quotes. TV show This Old House had one on a replacement. It may be available online. Home Depot or Lowes or Ace Hardware may be able to help, Or similar Hardware outlet in your area.
Feb 13, 2015 | Water Heaters
Hi we have an old topliss shower we think its from 1970s or 80s the shower head as broke the end were it screws off can we still get the old parts
Sometime in the 1990's laws were written regarding shower heads in America reducing everything to low flow shower heads exclusively which changed the whole industry and interchangeable parts went by the wayside. You may have better luck taking your old shower head to a local welder to see if it can be fixed. I think you could get another 30+ years out it if it was quality made in the first place.
Jan 23, 2015 | Home
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
On OpulenceTM SHOWER Trim Kit w/8incg Sunflower Showerhead, the water presure is too low on both hot & cold, seems like there isn't sufficent water to supply the 8inch head. the model number is 502057BNT....
Either this is a consequence of having a "low-flow" shower head, or the pipes are too small or have too many bends and elbows to support the flow rate required at 65 PSI for such a large shower head. What is the water pressure at the shower head fitting while the shower is running? It won't be 65 PSI, but it shouldn't be below the recommended inlet pressure for the unit.
Feb 26, 2018 | Danze Home
Low water pressure from shower head with the shower head removed
If you have good pressure at the water faucet close to the shower and low at the shower then the shower valve needs rebuilt. If you have low pressure at all then start going down the line toward the water service coming into the house looking for where the low pressure starts in the distribution system and you should be able to isolate the problem.
Feb 08, 2011 | Delta Home
Shower head
Jun 26, 2010 | Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
