Question about Jaguar 97-99 00 01 02 03 04 05 06 Xk8 R. Blower Motor
Hazard lights wont turn off - Jaguar 97-99 00 01 02 03 04 05 06 Xk8 R. Blower Motor
Where is the hazard light relay located?
The button is bad. the flasher is in the fuse panel.
Mar 15, 2016 | 1987 Cadillac Seville
Hazard warning lights wont turn off until battery disconnected.this is a jeep grand Cherokee limited 1997 4.0
Possibly four way flasher switch is defective,
Unplug wiring harness fro the back of the hazard warning light switch. if the lights stop flashing , replace the hazard switch.
Dec 29, 2015 | Jeep 1997 Grand Cherokee Limited
My Hazard Lights come on and can't turn off
Hi Todd:
I'd be thinking that the switch is defective.
The hazard lights are there for a reason so I would not disable them.
My suggestion?
Get the switch checked.
Aug 26, 2015 | Cars & Trucks
No turn signals. hazard lights work only when button is held in. Hazzards will not stay on. Is problem in turn sig switch or hazard light switch
If hazard switch wont stay engaged and the turn signals run through it I would replace hazard switch then retest
Apr 11, 2015 | Cars & Trucks
Kia hazard lights stay lashing even when the vehicle is not running and wont stop flashing
Has the HAZARD switch been activated? If the switch is off then there may be a problem with the switch or the flasher module.
Feb 20, 2015 | 2014 Kia Sorento
Hazard lights wont come when you push hazard button turn signals will not work push it again and they work
it sounds like the relay has gone for your hazard lights, when you press the button to turn them on, it will disconect the power to the main indicators hence wont work when hazards pused in, try locating either the hazard flasher unit, or the relay , have you checked the fuses?
Feb 01, 2010 | 2000 Hyundai Elantra
Turn signals wont work fuses are good?
the hazard switch above the radio is your problem. if you put on your signals and they don't flash turn hazards on then off and they will flash. (changing this *** will fix your problem
Aug 30, 2009 | 1999 Pontiac Grand Am GT
Jaguar 97-99 00 01 02 03 04 05 06 Xk8 R. Blower Motor Logo
261 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
