Question about Home
Vitra cistern parts
How do i remove the lid
  • 5 Answers
SOURCE: Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
Posted on May 18, 2009
  • 21 Answers
SOURCE: Replacement part for VitrA cistern
I trust you mean the "Flapper Valve". They are available and most hardware stores.
Get a Universal type as they fit most units. Take the old one with you. If you turn the water off at the wall it will stop it from running while you're away
Posted on Nov 27, 2009
  • 10865 Answers
SOURCE: I am trying to find
Hello. Call your local plumbing shops. Some of them store all of the used parts for this very purpose. If they don't have a lid, they may have a source nearby. Joe
Posted on Oct 12, 2010
SOURCE: How to remove lid on Kohler k-1833a cistern
Follow the instructions on p.12 of the following pdf:
http://www.geberit.com.au/web/appl/au/wcmsau.nsf/files/usr-pdf-Geberit_Outlet%20Valves.pdf/$file/Geberit_Outlet%20Valves.pdf
Basically, push down the 'full-flush' (big) side of the flush button and look at the side of the remaining (small) side of the button. There is a little slot that allows you to pull the small button out. You can then pull out the big side of the button which exposes a screw that allows you to pull the lid off.
Hope that helps.
Posted on Nov 29, 2010
  • 3 Answers
SOURCE: I have a Vitra dual
Have you tried to remove the outer ring by unscrewing it before you attempt to remove the buttons? I don,t think you should remove the buttons first.
Posted on Sep 01, 2011
Water level in new toilet bowl to low
water level in the bowl( pan) is determined by the height of the sewerage pipe level that it is connected to and is fixed by design and style of the pan
unless you are on about the water level in the cistern( tank) which you can adjust yourself
Nov 17, 2015 | VitrA Aria Toilet with Elongated Bowl/...
Vitra cistern parts
it could just be bad water pressure how are your cold taps in the same room?
have you used bloo loo type things in your cistern? there may be a blockage in your inlet or a build up of lyme.
check this
Jun 17, 2013 | Home
Is it possible to replace just the cistern instead of the entire toilet set? I have had water leaking problem in my toilet. The water is running from cistern to the bowl whenever the cistern is fille
It is likely that the leakage is being caused by a worn-out flapper or seal (the part the flapper seats on). You can buy after-market kits that have replacement parts. What is the make and model of your toilet?
Nov 30, 2017 | VitrA Aria Toilet with Elongated Bowl/...
Hi, Just moved into an apartment with two vitra retro toilets. As soon as you start to use them you can hear water running as you add waste to the toilet bowl. Is this normal? The developer tells me it...
check the type of fill valve that you have in the tank and check with a plumbing shop or better yet check your local lumber company as
they usually carry toilet replacement parts and you can read the instructions on how to adjust the one you have
Sep 22, 2017 | VitrA Aria Toilet with Elongated Bowl/...
I am trying to find a replacement cistern lid for a Vitra, can you help?
Oct 12, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Where I can buy vitra cistern lid?
try these guys, they have a very large selection...
http://www.toilettanklids.com/
Jun 17, 2010 | Home
Nov 26, 2009 | VitrA Aria Toilet with Elongated Bowl/...
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
