Kenmore 300 washer
Slow spen cycle nosie
SOURCE: Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
  • 92 Answers
SOURCE: kenmore washer spins very slow or not at all
yes the problem is that the bushes are badly worn on the motor,they are easy to replace and cost about £10.00 to renew
Posted on Jun 07, 2009
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
  • 67 Answers
SOURCE: washer bounces when spin starts and seems nosie
If it is brand new are the transit bolts removed? try spin with nothing in it and see if it turns smoothly, if not there is something broken inside, id spins smoothly it will be a fault in the dampers.
Posted on Apr 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer make a loud grinding nosie
It appears your clutch or tub bearing has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
How to fix washer leaking from bottom when spenning
Might be the hose from tub to pump or pump to outside. Check each by raising the unit and do a spin cycle.
Apr 22, 2014 | Sears Kenmore Elite 4.5 cu. ft....
When the machine is almost complete with the water draining cycle and starts to spen faster to dry the clothes, a knocking sound is heard then the machine slows down. This continues until the drying cycle...
This may just be an unbalanced load. Does this happen all the time? Is this a front or a topload unit? Try running a load with just a few light items and see if this happens again. If the light load works then you are overloading the machine. Reduce the number of items you put in. Don't put in single potentially heavy items like sweaters, coats or blankets with light items. Good luck.
May 01, 2011 | Maytag Washing Machines
It making a load buzzing nosie hafe way threw the cycles and it stops and my clothes are not rasied out and soaked still from not being spinned i dint put no more then usually iv had this probmle before...
F30 Dispenser system error . Bad or jammed motor, broken wire.
Remove the dispenser and put it in the dishwasher for a cycle. That will clean it up.
Take the bottom panel off and dump the pump filter.5cfa9a5.jpg0084008.jpg4d0f9ba.jpg
I have a service manual HERE with more info
Oct 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 300 washing machine warm water cycle is hot water
You have to check the thermostat connected to heater circuit.
Apr 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer make a loud grinding nosie
Jun 27, 2009 | Kenmore Washing Machines
Kenmore washer spins very slow or not at all
Jun 07, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Slow cycle making a loud CLACKING noise???
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Apr 08, 2007 | Kenmore 45981 Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
