Question about GPS
Tomtom problems Can not get the sign in page to operate when I put in the fourth digit it ceases after a time it will go back to start page I have a tom tom go 910
5 Suggested Answers
SOURCE: Tomtom GO 910
We have the same problem. It is a problem of contact. We have the same issues with the car adapter and the home adapter. If you hold the tomtom real firm on the adapter, it might load again, but you need to hold it. That is not a great solution! TomTom knows about this problem, but they don't solve it!!!!
Posted on Oct 08, 2008
SOURCE: how to reset tom tom 910
the reset hole is hard to find... If you are looking at the back of the unit, it is in the upper right hand side of the liitle plastic protrusion at the top of the semi-circular opening above where you can see the exposed circuit board.
Posted on Nov 25, 2008
  • 54 Answers
SOURCE: favorites button greyed out on tomtom 910
when you update the maps favorites are erased the favorites will also remain greyed out untill you have marked atleat one address or location as favorite
Posted on Dec 28, 2008
  • 171 Answers
SOURCE: The Logo screen freezes on start up.
Connect it to your pc then turn it on. It should either connect or ask you to connect to the pc. If tt home opens shut it down. Do a complete backup of your unit onto the desktop. DO NOT USE TOMTOM HOME TO DO THIS!!!! After doing a complete backup format the drive on your tt useing fat 32. Open tt home and let it reload your os. Do this a couple of times to get the newest os. Disconnect your tt from the computer the way you normally do and restart your tt. Reconnect your tt and do not let home start. Go to your backup and copy and paste your maps back onto the root of your tt. If you have any question email me.
Hope this helps
Posted on May 09, 2009
I need a manual for Tomtom GPS
You posted this question three times. When you post for the fourth time, please include the model of your TomTom device.
Jan 17, 2014 | Tomtom GPS
Even after replacing the toner cartridge the toner light remains on and the copier will not operate. I have tried agitating the cartridge with no effect. Occasionally on switching on it will operate for a...
Hi Paul
Please answer me a few questions and Ill look into your issue when I get some time later today
Are you using Sharp original toner or after market?
Is the light the "billard ball" one and is it on solid or blinking
Is the drum light on also?
What is the page count on this machine
"clear, density select, clear, density select, dilpay blinks 00 then use arrows for up, zoom for down, to put in 22, press copy then arrow in 05, press copy.. result will be 3x 2 digits repeaed, clear to exit to start of service mode
what is the drum count?, same as above but 12 instead of 05 for second lot of entry
TRy doing clear density, clear density, then 10 copy, can you hear toner motor turning for 30secs?
Dont play in service mode you can damage machine if wrong stuff is put in;)
(clear then clear again to exit all the way out of service mode)
Please post back results/answers
Cheers
Soulvisitor
Oct 10, 2011 | Sharp AL-1217 Copier
Red cross on sd card on startup
You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
Jun 17, 2009 | Tomtom GO 300 GPS Receiver
Hope this helps
May 07, 2009 | Tomtom GO 920 GPS Receiver
TomTom 920 GPS Antenna is not working (the black/orange indicator does not rotate)
After two attempts and no real solution do you think it is wise to go for a third time around? You should be insisting an an exchange since you have paid twice for a repair and they did not fix it! Get real!
Sep 17, 2017 | Tomtom GO 920 GPS Receiver
Tomtom one
Okay, I fixed it and came back to tell the story in case some poor soul finds their way here with the same problem. Some of these tomtoms come with guam as well as us and canada. we didn't fat finger it; for some reason tomtom home stored us and canada on the hard drive (g) and took it off the device when it did its first update.
First, plug your tomtom into the computer and go to "remove items" and remove guam. it will give you the option to store it on the g drive which i did, (in case I should take a notion to go there soon.) this provides more space on your device.
Now go to "add maps, traffic, etc," in tomtom home and scroll the arrow to page forward until you see "items on my computer." click this and then click maps. hopefully us/canada is there, thats where tomtom home had put mine. click "add" for that item and it should upload to your device. this takes a long time. there may be an application that tomtom still wants to update to your device. do this before turning the tomtom off from the computer, i couldn't see that us/canada was there until I did this, and then I had to turn the tom tom off, and bring it back into tomtom home two times before I could see it had the map and was working again.
your compass will also be messed up after you have done any updates at all to your tomtom. this is tom toms new application, there is nothing we can do about it until they fix it someday. the tomtom still works right, you just don't have the cool compass options you had with the original. if you did a back up before you initial update you can go back to the older application if you want.
hope this helps people, as you can see above i was very frustrated because the nice people who really did try to help in this and other discussions had not experienced the problem and did not know the answer. maybe tomtom udates does different things at different times, but this is what it did to mine.
Nov 25, 2007 | Tomtom ONE GPS Receiver
Red x on my tomtom go one
Tomtom GO 910 GPS Receiver flashing white X in a red circle
I discovered that there was a file on the 910 called CLMDATA which was corrupt. When I deleted this in Windows explorer, the unit started up and worked OK. This file is recreated when the unit starts up
Oct 28, 2007 | Tomtom GO 910 GPS Receiver
GPS Won't Turn On
Amazing what reading through the support page at TOMTOM reveals... I have the XL so no SD card to remove, but the support page explains that a hard reset by holding the power button takes 15 SECONDS. That's actually a really long time if you watch a clock. I pressed it and waited it out, and it worked. Powered right up. Not sure if I lost all my favorites and stuff but I have them backed up using TomTom Home anyway....
Dec 19, 2006 | Tomtom ONE GPS Receiver
GPS Logo
540 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
