Question about Retail Supplies
Verifone vx510 when I entered a credit card number a message settles TSYS came up along with a downward arrow in the bottom left hand side of screen. I couldn't process payment. how do I fix this? urgent
5 Suggested Answers
SOURCE: Verifone vx510 showing "no master key"
it message show in the pinpad or in the point of sale??? if it is in the pinpad you must re-enteder the master key number into a pinpad.
Posted on Mar 27, 2009
danielizapat
  • 96 Answers
SOURCE: We have the Verifone VX510.
call the verifone number on the machine try plugging it in to another phone line
Posted on Aug 04, 2010
  • 10 Answers
SOURCE: Our Verifone VX510 printed our
This problem could have multiple causes. It sounds like you are receiving a settlement error, which are specific to each merchant services provider. You will have to call the merchant services provider so that they can look up the error message on their end and tell you what is causing the error. For example, the error message that you would receive if you use First Data would be different than the message you would get if you used Bank of America. Your terminal will not let you run any more cards until you resolve the settlement error. This is to prevent you from continuing to run cards in a corrupted batch, or a duplicate batch.
Posted on Jul 29, 2011
SOURCE: VeriFone VX510 "TCP Error 10030003" is the error
Tcp ip errors 1001 to 1009 are going to be communication errors regarding your isp equipment. The first thing you want to do is not just power cycle your terminal but also the router and modem or just the one if you have a combo equipment. Just like the commercials use to say when your online your router may just go down quietly. So after unplugging everything wait about 2 mins and plug back in the router/modem wait for the lights to become silent all except the online light which should flash. Then once those return plug in your credit card terminal and attempt a transaction as normal if your still getting the error more then likely its an issue with your internet processor and i would advise calling to see if there is maybe an outage
Posted on Aug 15, 2013
What does must settle TSYS MEAN WONT TAKE CARD
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Sep 19, 2014 | VeriFone VX510
Batch out omni 3730
in order to settle or batch you will press the purple "more" key or the purple key to the far left until you see settle or close, then confirm amount. if you get a error message you will need to call your processor. if you get a QD followed by numbers or RB followed by numbers you need to call processor. if you take tips and have not adjusted them it will prevent from settling at times, check your sales by printing a report, press the purple key to the right of the alpha key above the 2. check your reports and try again. if you are getting can not connect to server or host, then you do not have a good phone or Ethernet connection. check those and reset the modem or terminal by unplugging and plugging back in right away. may need to leave unplugged for 60 seconds if it does not reboot it self.
if you lost the sales call processor.
Jul 29, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
What does card no. error mean after trying to process a credit card
the credit card number you are entering is not recognized by your terminal as either a card type you don't accept or you are not entering the number correctly
May 20, 2014 | VeriFone VX510
How can I turn off the print for settlement every night on a Verifone 510?
hit arrow down to "other set-up", select that, then keep hitting the next button until you get to auto-settle, hit edit, select off, hit exit, hit confirm changes, then press the cancel/clear key to exit set-up mode.
Jan 02, 2013 | VeriFone VX510
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
How do i reboot
To Reboot the Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
Aug 31, 2012 | VeriFone VX510
Our Verifone VX510 printed our detail report at closing last night, but the settlement failed multiple times. Now we are unable to use the machine to process a debit or credit card transaction because it...
Jul 15, 2011 | VeriFone VX510
The amex card not read by machine. it shows on the screen:- settlement failed...
ANY card swiped when machine returns settlement failed error will probably return the same error. It's not the card - it's the batch stuck inside the machine. Whether manual batch or autobatch, sometimes the data IS actually transferred completely out of the machine but somehow the machine doesn't get that message from the backend server that settlement was completed *settlement failed* , there may have been some corrupted files, or maybe the settlement really did fail and is stuck and needs to be settled/batched out/transmitted to free up that terminal. Try simply settling that machine - press the down arrow (far left purple function key) ; press F2 Settlement and follow prompts.
Mar 29, 2011 | VeriFone VX510
Retail Supplies Logo
26 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
